Author Topic: WTB: Millipede board and Centipede CP  (Read 1750 times)
cscon115
  • Last login:June 12, 2009, 02:45:29 pm
  • Sock it to me!
« on: July 03, 2007, 03:04:10 pm »
Folks,
** I am looking for a millipede board so I can convert my centipede to a multipede.
** I am also looking for the metal control panel for a centipede box
     PLEASE, don't be embarrassed if you think your CP is not good enough or if it is pretty beat up.
    I am a restorer - so I would only alter something that is kinda beyond repair, like an already altered CP.
    I would only do this to a beat up control panel, I want to modify the CP as follows:
        1) Open up the trackball hole so it will take a 4" ball (not the standard 2.5")
        2) Weld the bolts that hold the trackball in place so the top is flush
          (that way there would be no bolt heads showing)
Dan
Ronald Reagan is too liberal for me.
cscon115
  • Sock it to me!
Re: WTB: Millipede board and Centipede CP
« Reply #1 on: July 04, 2007, 12:02:58 pm »
Ok,
I was misled by a friend who told me Millipede boards and Centipede boards are interchangeable - they are not.
So I am not looking for a Millipede board (for now).    I plan to figure out how many signals need to be swapped in order to make the millipede work.
Next I think I will try to layout a board that will be inserted between a millipede and the centipede connectors so I don't have to hack the harness. (I JUST CAN'T DO THAT!)
If I layout a transition board or hack a jamma board I will post my results for all to see!
Thanks for all the PM's about the boards!
Dan
« Last Edit: July 04, 2007, 12:05:06 pm by cscon115 »
Witchboard
« Reply #2 on: July 04, 2007, 10:28:48 pm »
The most simple, but maybe not affordable method would be getting a Millipede board and purchase a Multipede kit and connecting it in your Centipede cabinet with a Millipede to Centipede cabinet adapter.  If you buy them both at the same time they cut $5 off the price.
