Author Topic: visual pinball and pinmame not working?  (Read 2890 times)
tyweed
  • Last login:March 09, 2008, 01:29:03 pm
« on: April 22, 2003, 12:52:58 pm »
I just recently setup my pinball and its loading games ok but i'd say about 90% of them when you get them loaded the pinmame screen says " factory settings restored clear bookmarking" and then i cant add money , use the flippers, or even start game? any ideas why?  is this a rom problem?
I downloaded my roms from aj's site and some files seemed a bit smaller then they should have been.
oh also 1 last thing everytime you click escape then quit editor the visual pinball window opens with that tables drawing on the editor is there a way to just escape completly and not have to close that window everytime as well?
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
Re:visual pinball and pinmame not working?
« Reply #1 on: April 24, 2003, 06:36:16 pm »
I think there is a FE out there for Visual Pinball. The FE would take care of the issue when you hit ESC.
As for the ROM's, I am not sure. I know my Visual Pinball AND PinMame both expired and I had to get new versions to get it working again.
But since you see the tests being run yuo obviously have a different problem.  Have you hit F3 or 'END'? 'END" opens and closes the coin door.  F3 restarts the ROM. Sometimes you have to restart them....
paigeoliver
  • Awesome face!
« Reply #2 on: April 25, 2003, 08:03:28 am »
I once attempted to navigate the halls of pinball emulation/simulation and failed miserably as well. I couldn't really figure any of it out. Maybe I just wasn't trying hard enough, but it seemed pretty darn complicated.
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« Reply #3 on: April 25, 2003, 08:05:29 am »
Howie has something on his Lazarus-site to help with VisualPinball -vplauncher or something similar.
With this, you can run it via commandline like in MAME without these problems. It works! :)
paigeoliver
  • Awesome face!
« Reply #4 on: April 25, 2003, 08:10:11 am »
Thanks for the head up Carsten Carlos. I might check that out sometime. Probably not soon though, as simulating pinball has become less of a priority since I got a real pinball machine!
Carsten Carlos
« Reply #5 on: April 25, 2003, 09:03:20 am »
One day I must have a real pinball too - or build one myself!  :D
Better not - building my cab was expensive enough, I'm sure even a real one would be less expensive!
(Though it must be a cool one -like Addams Family or one of those featuring Elvira?)
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #6 on: April 27, 2003, 02:42:37 am »
tispossible to emulate pinball??!!??
is there a black knight 2000 available????????
Slow In Fast Out
Carsten Carlos
« Reply #7 on: April 27, 2003, 05:54:42 am »
yep!
yep!
http://www.vpforums.com Better start researching here -its all a bit complicated to get it working.
tyweed
« Reply #8 on: April 28, 2003, 12:41:58 pm »
carlos are you usinghiwards wrapper for visual pinball. i'm havng a very difficult time getting it running i was just curious
