Author Topic: hook up wire sizes in ireland  (Read 1047 times)
gosullivan
  • Last login:June 08, 2013, 07:05:08 am
« on: June 30, 2007, 09:50:43 am »
hi,
Am trying to find some wire for connecting joysticks and buttons in Ireland, does anyone know if either of these are the same as 22 AWG hook-up wire?
http://www.peats.com/cgi-bin/test_new/catalog.cgi?view_product=1&id=3517
Technical Specifications
Size:   16/0.2mm (0.5 square mm).
Rating:   3.0A at 1000V RMS maximum.
O/D:   1.6mm nominal.
Wall cover:   PVC 0.3mm to DEF61-12 Type 2.
Core:   Stranded 16 x 0.2mm tinned copper conductors.
http://www.peats.com/cgi-bin/test_new/catalog.cgi?view_product=1&id=3579
Size:   24/0.2mm (0.75 square mm).
Rating:   4.5A at 1000V RMS maximum.
O/D:   2.3mm.
Wall cover:   PVC 0.6mm to DEF61-12 Type 2.
Core:   Stranded 24 x 0.2mm tinned copper conductors.
thanks,
Gerard
Ed_McCarron
Re: hook up wire sizes in ireland
« Reply #1 on: June 30, 2007, 10:45:40 am »
Just going by ampacity, the 3.0A one is between 24-26 AWG, and the 4.5A one is between 24-22 AWG.  For connecting joys and buttons, both are OK.
The smaller wire will work fine, electrically, as long as it is compatible with whatever connectors you are using.
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
gosullivan
« Reply #3 on: July 01, 2007, 10:43:04 am »
thanks for the help, I think I'll give the 4.5A wire a go, don't fancy hacking away at cat5  :)
