Author Topic: Checking Voltage  (Read 1158 times)
Hawk Daddy
  • Last login:June 15, 2025, 03:10:44 pm
  • Only True Pimps Have Arcade Machines!!!
Checking Voltage
« on: June 28, 2007, 07:54:52 pm »
I need to check the voltage on my power supply.  I have a digital meter, and I would like to know what setting I use to check the voltage.  Also what do I use as test points?  I was thing just connecting it to the positive, and negative on the switcher.  BUt I need to know what setting to set it on for the meter to read less then 5.5. cause I don't want to mess up my new board.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Steel Talons 2 player helicopter game
hng
  • Last login:July 27, 2007, 02:07:23 pm
    • myspace
Re: Checking Voltage
« Reply #1 on: June 28, 2007, 08:08:15 pm »
You should set the meter to read HIGHER than the expected output voltage.   Most meters have a 20 volt setting. Use that. Put the black to  black, and the red to red, and you should be set.
Hawk Daddy
« Reply #2 on: June 28, 2007, 08:25:50 pm »
I'm talking about like, acv, dcv, ohm, dca, and then like 500v, 200v, 20v, 2v, cause I'm pretty sure it has to be on DCV, then I need to know if i need to check it with 500v, 200v, 20v, or 2v, setting, and then what am I looking for when I do, I'm a complete noob at checking voltages.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Hawk Daddy
« Reply #3 on: June 28, 2007, 08:32:57 pm »
I think I got it, I put it on 20v, and got a reading of 5.29. Is that too high, the board that I have says not over 5.5 v, and 5.29 isn't that far away from it.  Just let  me know.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #4 on: June 28, 2007, 08:52:32 pm »
Hawk... 5.29V is way less than 5.5V  don't worry, that's fine. If you're measuring the power supply output under a no load condition (i.e. you don't have anything but the meter connected to it) then it will read more than 5V .... But when it is under load (i.e. your board is connected)  that output will drop slightly. Which is why you're reading 5.29V. It should drop to just over 5V once you get it connected up.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
Hawk Daddy
« Reply #5 on: June 28, 2007, 09:03:06 pm »
Thanks fozzy, I hooked up the board, and it worked perfect, today I haven't did anything to the control part of the harness, so all that I could do was jut look at the screen, and listen to the music.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
