Author Topic: Help with "rattley" Happ trackball  (Read 1469 times)
QuixoteQuest
  • Last login:October 18, 2010, 07:24:11 pm
« on: June 26, 2007, 04:37:00 pm »
Got a new USB/PS2 3" Happ trackball for Christmas (in a new cabinet). It was a little tight at first, but has broken in to be quite smooth and enjoyable. However, recently it started feeling a bit "rattley" in the hand. It's hard to describe, but it just doesn't feel or sound the same. It seems to function fine. But the feel seems a little "off" and it sounds noisier when spun. It had a little oily-dust-gunk like any ball mouse would get, but even when cleaned off it still feels the same.
Anyone understand what I'm describing? Is this a normal issue or is there something I need to clean? Any disassembly requred?
ChicagoDave
  • Last login:May 18, 2023, 11:08:23 am
    • Dave's Website
Re: Help with "rattley" Happ trackball
« Reply #1 on: June 26, 2007, 05:09:27 pm »
I had this problem happen after the kids had some pizza.  They didn't wash their hands and started playing with their greasy little paws.
It was the grease on the trackball that was making the noise.  I wiped it down using a paper towel with some Windex on it and it solved the problem.
Homer Simpson:
"Here's to alcohol, the cause of, and solution to, all life's problems."
BobA
  • What Me Worry?
« Reply #2 on: June 26, 2007, 10:44:52 pm »
If you do not get satisfactory operation after external cleaning you might want to see that the rollers are clean as well.
northerngames
  • Trade Count: (+18)
« Reply #3 on: June 26, 2007, 11:55:20 pm »
give each bearing a fling and it should spin for a few seconds if it is slow and stops rather fast the bearing is going bad I just tested mine and found one to be bad.
