Author Topic: Best caster height for Saint book cabinet and another question while I'm here  (Read 1289 times)
GAtekwriter
  • Last login:July 16, 2011, 09:55:44 am
In the book, Saint recommends 2" casters and then states to add some shims to give the casters just a bit more distance from the bottom of the cab.  He doesn't say how far exactly and a search has turned up little.
I bought 2.5" casters and the clearance looks good, but I was wondering if anyone here has experimented with the best height/clearance?  The 3" casters looked WAY too big and I was imaging the cabinet being too high off the floor.
Any comments/opinions will be appreciated.  And while I'm here, I've got my base built and have 1 more question before I continue with the cab.  I'm on hold waiting to find the 1/16" slot cutter for my t-mold slot.  I'm most likely going to have to order it, so I just want to make sure it's 1/16 and not 1/8.  I've read a couple of different sizes and just double-checking before I spend the $.  1/16 or 1/8?
Thanks, All.
Jim
ChicagoDave
  • Last login:May 18, 2023, 11:08:23 am
    • Dave's Website
I used 3" casters and they came out perfect.
Homer Simpson:
"Here's to alcohol, the cause of, and solution to, all life's problems."
Xam
  • Last login:July 18, 2011, 11:16:45 pm
  • " Oh my heavens; good gracious. Cro-Magnons."
I used 3" and was also skeptical of the height. My fears were unfounded as 3" seems perfect for my cab. I think 2.5 would allow my cab to drag on the carpet.
Xam
Can't talk to a psycho like a normal human being.
Dmod
  • Last login:July 12, 2012, 06:50:45 pm
I used 3" on mine as well and it worked out fine.  Slot cutter should be 1/16"
My Projects:
Suspended Animation Scratch-built Cab
Driveshaft Arcade Seat Platform
GAtekwriter
Thanks, all... appreciate the confirmation on the slot cutter, too.
Jim
