Author Topic: MaLa Tree  (Read 3141 times)
dalto
  • Last login:June 23, 2007, 01:43:48 am
MaLa Tree
« on: June 23, 2007, 01:31:06 am »
Hi,
I have configured MaLa to use MAME and another emulator.  If I use a traditional layout, everything works fine.  I can switch between emulators and gamelists without issues.
However, when I try to setup MaLa Tree, the emulators in the drop down box are MAME and Jukebox.
Does anyone on know what I need to do to get the other emulator I have configured to show up?
Any help is appreciated.
loadman
  • Moderator
    • MaLa
Re: MaLa Tree
« Reply #1 on: June 23, 2007, 05:39:10 am »
I'm sure someone will point you in the right direction, as there are a few MaLa Tree users out there.  ;)
Can somwone please add these details to the MaLa Wiki.
http://wiki.arcadecontrols.com/wiki/Mala_Tree
Dmod
  • Last login:July 12, 2012, 06:50:45 pm
Re: MaLa Tree
« Reply #2 on: June 23, 2007, 06:47:48 pm »
I recall having similar problems when I first set up my MaLa Tree config.  I'm not sure how I solved it, but after a lot of playing with it, I got the other emulator to show up when using the tree editor.
I'm looking through my option pages now and I don't see anything particularly special, but I do have an additonal emulator set up under "Other Emu Config" and a Game List under "Game Lists" that uses that emulator.
I think I tried deleting my other Emu Config and recreating a new one after I had "Use Tree" selected.  Not sure if this is what got it to start working tho.
Sorry I can't be more helpful.
My Projects:
Suspended Animation Scratch-built Cab
Driveshaft Arcade Seat Platform
