Author Topic: Monitor burn in  (Read 1002 times)
madgammer
  • Last login:May 29, 2012, 06:03:58 pm
Monitor burn in
« on: June 22, 2007, 08:01:48 pm »
I just got a MK3 dedicated cab and noticed that it had a little burn in from the credits.  I was looking at it during the day and outside so it was a bit more obvious then outside or at night.  Is there any way to decrease the burn in or fix the monitor?  I don't think it would be too bad once it's in a darker room, but if it can be fixed or adjusted even better.
Worse case scenerio how hard is it to replace the monitors on those cabs?
BobA
  • What Me Worry?
Re: Monitor burn in
« Reply #1 on: June 22, 2007, 09:02:51 pm »
Put tinted plexi, tinted glass or sunshielded plexi over it and you will never see the burn.
