Author Topic: Pong knob on Oscar Spinner  (Read 1539 times)
paigeoliver
  • Awesome face!
« on: April 21, 2003, 02:32:57 am »
I have most of a 70s arcade spinner assembly. It isn't a genuine Pong one because the knob is metal.
It looks like the spinner on this game here.
Anyway. I was wondering if that knob could be used with an Oscar spinner (the spinner itself was designed to turn a POT rather than an encoder wheel, otherwise I would be using it as is).
Birdtales
  • Last login:October 06, 2020, 10:00:31 am
  • You won't like me when I'm angry.
    • Birdtales
Re:Pong knob on Oscar Spinner
« Reply #1 on: April 21, 2003, 10:53:54 am »
As long as it fits a 1/4" shaft I dont see why not.
Coming Soon
OSCAR
    • Oscar Controls
« Reply #2 on: April 22, 2003, 12:15:50 am »
Correct.  As long as the knob is designed for a 1/4" shaft and uses some kind of set screw and not a roll pin (like some did), you should be okay.  Some spinners, Blasteroids is one, used an 1/8" shaft and the knob is molded on.
paigeoliver
  • Awesome face!
« Reply #3 on: April 22, 2003, 12:40:51 am »
Thanks. I was looking at it more closely, and I can't seem to figure out how to get the knob off. It has a little hole on either side, but it looks to me like you can see right through from one to the other.
I guess I will probably just fork out the bucks for the knob too.
