Author Topic: MaLa and rotating games on exit  (Read 17729 times)
squirrellydw
Re: MaLa and rotating games on exit
« Reply #40 on: July 31, 2007, 09:37:36 pm »
OK, I finally was able to try this and it worked, however is there a way to have it so the dialog box does not show up?  I have to use the keyboard to select OK and I don't want the keyboard hooked up all the time.
I b**ch. People listen!!
loadman
    • MaLa
« Reply #41 on: July 31, 2007, 10:12:20 pm »
 :laugh2: Yes I only put that dialog box for de-bugging purposes. Good to hear it works for you
Try the attached version without dialog box
« Last Edit: August 11, 2007, 07:19:07 pm by loadman »
squirrellydw
« Reply #42 on: August 02, 2007, 09:39:27 am »
it worked, that you.  Now how do I add other games to it?
loadman
    • MaLa
« Reply #43 on: August 02, 2007, 07:26:45 pm »
You can't because its' hard coded   :laugh2:
But if you are a good boy I will change it to read a text file or something  :)
squirrellydw
« Reply #44 on: August 02, 2007, 08:31:55 pm »
 :notworthy:
loadman
    • MaLa
« Last Edit: August 11, 2007, 06:34:25 am by loadman »
