Author Topic: MaLa and rotating games on exit  (Read 17574 times)
squirrellydw
« on: June 15, 2007, 05:47:17 pm »
I have a 3 sided cocktail table and most games work great but I only have a trackball and spinner on the 3rd CP.  Some games like Centipede I have set to play vertically on the horizontal screen side.  When I exit the game it rotates the MaLa game list menu like it is set up to do BUT I don't want it to rotate after that game.  Anyway I can change this so it doesn't rotate?
I b**ch. People listen!!
loadman
    • MaLa
Re: MaLa and rotating games on exit
« Reply #1 on: June 15, 2007, 08:41:06 pm »
 :dunno  You might have to put it in a seperate gamelist
squirrellydw
« Reply #2 on: June 15, 2007, 09:17:30 pm »
I don't wanna use a separate game list.  any other ideas, can I modify the ini somehow of the game?
loadman
    • MaLa
« Reply #3 on: June 15, 2007, 10:35:42 pm »
You can modify each mame game with a separate .ini for rotation settings But how is that going to help you, as MaLa is the thing you want to control isn't it?
MaLa can be set to follow match the gamelist rotation or on a per game basis (to match) or ignore it all and just stay in the default position.
You can't tell MaLa to do the opposite to the game.
« Last Edit: June 15, 2007, 10:39:35 pm by loadman »
squirrellydw
« Reply #4 on: June 15, 2007, 11:20:21 pm »
No big deal I can live with it......maybe a future version a MaLa will allow you to make exceptions to rotate on certain games??
shock_
  • Last login:January 30, 2020, 06:23:29 pm
  • In Brisbane, it's GMT+10 all the time.
« Reply #5 on: June 16, 2007, 09:36:59 am »
Just played around trying to work out what you were saying, but now I get it.  If a game is vertically orientated, even if it's played at 0° rotation inside MAME (ie horizontally) MaLa will respond by swapping into vertical mode.
So the enhancement you need is for MaLa to watch for the last-known video orientation from MAME rather than just (presumably) reading the relevant data on the ROM.
Have you tried the other option, which is to bind a button or a shifted button to rotate MaLa, and then MaLa causes MAME rotate to suit?  This seemed to work better for me when I tried it a moment ago.
You're going to be telling something which orientation you want to play it in, so make it MaLa rather than MAME, since it works better for what you need to do this way.  To stop playing Gyruss and start playing Centipede, you'd move your seat around to the trackball side, hit the MaLa rotate button so you can see what you're doing again, find Centipede and launch it.
squirrellydw
« Reply #6 on: June 16, 2007, 11:11:48 am »
I will try the shifted button option.  You skin you made me and for MaLa is great, I will take some pics of my finished cocktail table soon.
shock_
« Reply #7 on: June 16, 2007, 08:11:13 pm »
I saw a pic in your project thread with the lid off, but the monitor running.  Looks nice  :applaud:
I've been combining my multi-emulator plans with that Applesque skin lately and it's working out quite nicely.  Changing emulators and gamelists on the fly without using MaLa tree :)
My cab will only have two sides, but since the screen rotates I am faced with similar issues as you, ie. only one CP has a trackball, but the screen might not agree with where the game thinks it is at all times.
« Last Edit: June 16, 2007, 08:17:49 pm by shock_ »
squirrellydw
« Reply #8 on: June 16, 2007, 08:26:48 pm »
Nice layout, I really like the icons on the bottom.  Any chance you could add something like that to the skin you made me if I tell you what I want?
loadman
    • MaLa
« Reply #9 on: June 16, 2007, 08:40:13 pm »
Ditto...  Both your Tables are supa kewl (as my son would say). My table is just a two sided vertical.
Anyway.....
As for the original question. I had another thought.  We could make a quick custom plug-in. If the game appears on this list MaLa will rotate a certain way.
If you want to try that send me a list of games and what you want it to do eg 0deg 90deg 180 deg etc
Any should it only happen on game exit???
squirrellydw
« Reply #10 on: June 16, 2007, 09:28:16 pm »
I will send you a list and yes only on game exit.  I can tell you some of them now off the top of my head.  All vertical games that require a trackball, spinner or steering wheel.  Centipede, arknoid (spelling), spyhunter.  thats all I can think of.  It would have to rotate 90deg to the right for my setup or I guess 270 deg to the left??.
loadman
    • MaLa
« Reply #11 on: June 16, 2007, 10:50:56 pm »
Kewl.. I'll get on it.
Just confirming that this needs to be set for certain games. Can we just have this rule apply to certain gamelists or does it have to be on a game basis?
« Last Edit: June 16, 2007, 10:52:39 pm by loadman »
shock_
« Reply #12 on: June 17, 2007, 01:12:58 am »
PM sent.
squirrellydw
« Reply #13 on: June 17, 2007, 01:54:39 am »
I would prefer just certain games,  I like to have all my mame games in one list and other emu is another.
squirrellydw
« Reply #14 on: June 17, 2007, 01:55:13 am »
PM sent.
got it, I will try to send you an idea this week
squirrellydw
« Reply #15 on: June 17, 2007, 06:41:10 pm »
If you could combine yours with this it would be great.  I like how Knievel has this but I like you icons.  If you can make the joysticks BLUE that would even be better.
For selecting games mine is set up as.....UP and DOWN scrolls and LEFT and RIGHT goes by letter.
Let me know what you can do and it would have to be for both the vertical and horizontal layout.
loadman
    • MaLa
« Reply #16 on: June 18, 2007, 07:43:39 am »
OK try a game of ROM name= 'CENTIPED' with the attached plug-in and tell me what happens  :o
« Last Edit: July 13, 2007, 09:36:21 pm by loadman »
squirrellydw
« Reply #17 on: June 18, 2007, 09:38:18 am »
Let me see if I can explain this....
When the game list is on the vertical menu screen and I exit the game it rotates in the correct horizontal position.  But if I select it from the horizontal menu screen and then exit the game it rotates back to the vertical position.
I will post a little movie clip of it for you.
squirrellydw
« Reply #18 on: June 18, 2007, 09:57:01 am »
Here is the quick video I shot, hope it helps.
squirrellydw
« Reply #19 on: June 18, 2007, 10:09:47 am »
I also just noticed that it rotates all the games incorrectly.  I tried MK3 and it rotated from horizontal to vertical on exit.
shock_
« Reply #20 on: June 18, 2007, 11:41:38 am »
Not sure exactly what parts you want me to replicate, and in what style... see attached ??
« Last Edit: June 18, 2007, 11:43:13 am by shock_ »
squirrellydw
« Reply #21 on: June 18, 2007, 11:50:36 am »
that looks great.  Can you somehow add/fit in load game, insert credit and select player?  Also will there be enough room on the vertical layout?
shock_
« Reply #22 on: June 19, 2007, 08:51:51 am »
I'm a bit concerned at the legibility on your screen - although the huge-ness of it should help somewhat :)
See attached - is this headed in the right direction?
(nice thread self-hijack here, too... we're all working on your cabinet right now  :laugh2: )
squirrellydw
« Reply #23 on: June 19, 2007, 09:19:09 am »
I like that.  Can you make all the buttons black and make the wording bold like in the first one you posted?  oh one other thing, can you make the blue a little brighter and bolder like on yours that surrounds 'arcade".  Maybe not as bright blue but brighter than what I have now?  Sorry for all the changes but you really do great work.   :notworthy:
edit....How about on the top put the joysticks in the middle and the EMU button on left like it is and the LISTS button on the right.
« Last Edit: June 19, 2007, 11:36:16 am by squirrellydw »
shock_
« Reply #24 on: June 20, 2007, 10:14:19 am »
Done.  Sorry, I looked at your cab photos and completely didn't see that. I had it in my head that your 1up and 2up were white and the rest black.
Font is back to "Slicker" which is the gamelauncher font, as well as what Knievel used by the looks of things, and (I think) what is printed on your buttons.
Done - since you did the "bow down" emoticon again ;)  Blue enough for you?  I have left the secondary snap window a little more washed out to increase the sense of depth for it.
Done.  The balance definitely looks better.
If I ever visit the USA, you so owe me a beer :)
squirrellydw
« Reply #25 on: June 20, 2007, 10:59:24 am »
 :notworthy:  perfect, and if you visit the US I will buy you a few beers.   :cheers:  Thanks, let me know when I can download it or email me at
squirrellydw at gmail dot com
shock_
« Reply #26 on: June 20, 2007, 05:29:17 pm »
attached.
« Last Edit: June 21, 2007, 10:02:15 am by shock_ »
squirrellydw
« Reply #27 on: June 20, 2007, 06:02:58 pm »
just use the one that I attached in the last message, but save the new images instead :)
Do I need to rename them to match what I have now or just keep them the same?  I am sure I can figure it out but I am at work right now.
squirrellydw
« Reply #28 on: June 20, 2007, 11:48:59 pm »
Sent you 2 PM's shock
squirrellydw
« Reply #29 on: June 22, 2007, 10:56:36 am »
Any update on the plugin Loadman?
loadman
    • MaLa
« Reply #30 on: June 22, 2007, 06:43:12 pm »
The only way I can make it work the way you want is to put a timer on the plug-in. That effectively means there would be a delay of up to sec before it rotated back to the position you want after playing certain games. Otherwise MaLa will overide it
Is that acceptable?
squirrellydw
« Reply #31 on: June 22, 2007, 07:40:33 pm »
wow a hole second  ;)  yeah I can handle that.  I have no idea what the timer really has to do it with it but whatever, you are the programer I just play games.  I won't be able to test it out till next weekend though, I am on vacation starting now  :applaud: :applaud:  :cheers:
loadman
    • MaLa
« Reply #32 on: June 22, 2007, 09:12:36 pm »
OK Enjoy your 'break'  ;D
I will post my next version on this thread later   ;)
squirrellydw
« Reply #33 on: July 01, 2007, 12:11:44 pm »
how is it coming along, I am ready to test :)
loadman
    • MaLa
« Reply #34 on: July 02, 2007, 06:45:46 am »
I have written it so that it pops up with a message if it detects you just played a game on the 'Rotate list'  .So many distractions.  I will finish it soon  ;)
loadman
    • MaLa
« Reply #35 on: July 13, 2007, 09:34:19 pm »
Ok try this:  attached
At the moment it is hard coded just to react to the rom name 'CENTIPED'.
It waits a sec or so after you quit a game
Let me know how you go.
If it's OK I will mod it so it will read a text list of rom name on start-up or something so it just does not work for CENTIPED  8)
« Last Edit: July 20, 2007, 08:07:23 pm by loadman »
squirrellydw
« Reply #36 on: July 14, 2007, 12:51:50 pm »
 ???  nope, still rotated, nothing seemed to happen  :dunno
loadman
    • MaLa
« Reply #37 on: July 14, 2007, 07:39:50 pm »
Really,,,
Do you have that rom name?  'CENTIPED'
procedure MaLaGameQuit(); cdecl;
begin
     if sgame = 'CENTIPED' then
     Rotate.Start;  // Rotate after 1 sec delay
end;
Give me a few 'rom names' you have so that I can add it to the code
« Last Edit: July 14, 2007, 10:24:37 pm by loadman »
squirrellydw
« Reply #38 on: July 15, 2007, 09:32:33 am »
I checked and I do have that rom along with centipd2, centipdb and centtime
loadman
    • MaLa
« Reply #39 on: July 20, 2007, 08:08:43 pm »
Ohh, Maybe it's case sensitive
Try this (attached)
if (sgame ='CENTIPED')
     or (sgame ='centiped')
     or (sgame ='centipd2')
     or (sgame ='centipdb')
     or (sgame ='centtime')
        then
« Last Edit: July 31, 2007, 10:13:36 pm by loadman »
