Author Topic: Starting Mala w/windows and LEDwiz plugin  (Read 6212 times)
squirrellydw
« on: June 11, 2007, 09:44:56 am »
I am getting a error with the ledwiz plugin when I have Mala start with windows, it's almost as if it can find it?  I will try to write down the error when I try it again.
By the way when is the next update to the ledwiz plugin, 2.5 or 3?  I had made a few suggestion  :)
I b**ch. People listen!!
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
Re: Starting Mala w/windows and LEDwiz plugin
« Reply #1 on: June 11, 2007, 10:11:57 am »
hey squirrelly... sorry for the lack of postings lately.. started a new job recently and have been swamped.
loadman has the bug again to code up some enhancements for our ledwiz plugin.  his excitement is rubbing off on me as well. :)
things should level off for me soon and I can jump back in.
loadman
    • MaLa
« Reply #2 on: June 11, 2007, 07:14:53 pm »
That bug is fixed in the next vers  ;)
Was to do with current directory...
What were your suggestions again ? We have a list but just in case we missed one.
squirrellydw
« Reply #3 on: June 11, 2007, 08:00:33 pm »
thanks
making player two buttons light up was one of them.  Would like to be able to remap the button like LEDBlinky but not sure if you can do that.  I am going to test LEDBlinky out this week to see if that is better for me.
loadman
    • MaLa
« Reply #4 on: June 12, 2007, 06:24:53 am »
thanks
Yep that is on the list  ;)
If LEDBlinky does not suit your cab let me know I will e-mail you a patched version for the start-up bug
loadman
    • MaLa
« Reply #5 on: June 16, 2007, 08:49:36 pm »
Oh yeah...  Fix-up version is attahed to this thread. I forgot  :banghead:
http://forum.arcadecontrols.com/index.php?topic=64275.msg650356#msg650356
squirrellydw
« Reply #6 on: June 16, 2007, 09:23:06 pm »
thanks, but I think  Arzoo LEDBlinky is best for me since I remap some of my controls with my 3 sided cocktail
loadman
    • MaLa
« Reply #7 on: June 16, 2007, 10:49:13 pm »
No Worries  ;)  But if you get a chance could you test it for me anyway  ;D
squirrellydw
« Reply #8 on: June 17, 2007, 01:52:46 am »
Ic an do that for you since you have helped me with all my stupid questions.  I will try this tomorrow
squirrellydw
« Reply #9 on: June 17, 2007, 10:05:44 am »
Hey loadman, I just realized that it might not work for me correctly anymore.  I did a little rewiring the other night so things might have changed.  I won't be able to tell if my buttons are lighting up correctly anymore.
loadman
    • MaLa
« Reply #10 on: June 17, 2007, 07:14:18 pm »
That's cool
It's just the
bit I would like you to test please...
squirrellydw
« Reply #11 on: June 17, 2007, 09:02:35 pm »
I just tried it and it seems to work fine, no error message on reboot.  Is there a log file you need or anything?
loadman
    • MaLa
« Reply #12 on: June 17, 2007, 09:27:32 pm »
Nope .. Thanks   ;D  :cheers:
squirrellydw
« Reply #13 on: June 17, 2007, 11:25:32 pm »
no problem, you have helped me out a lot
« Last Edit: June 18, 2007, 10:10:10 am by squirrellydw »
