Author Topic: Question about button sizes  (Read 1561 times)
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
« on: June 06, 2007, 07:47:48 pm »
Are the buttons hole size typical the same say as the holes for joysticks on control panels.  I am asking because I plan to get a bartop kit from mameroom and get it drilled for two u360 sticks and 6 buttons in the middle.  For the time I will only be using 1 joystick and want to plug the whole with either another button or a button stopper.
DaveMMR
Re: Question about button sizes
« Reply #1 on: June 06, 2007, 08:01:46 pm »
I'm assuming I did it correctly when I say that I used the same spade bit to cut the button holes and the joystick hole for the U360's (1-1/8").  If not, it seems to work fine otherwise.  ;)
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: June 07, 2007, 12:20:11 pm »
They can be the same size.  But sometimes, especially on wood CPs that the joystick are mounted the full thinkness (no routing), the joystick hole needs to be bigger or the distance of travel is restricted.
Better ask mameroom what they do.
Robin
Knowledge is Power
DaveMMR
« Reply #3 on: June 07, 2007, 08:43:59 pm »
Really?  I don't recall hitting any sides of the wood on 3/4" and there are no restrictor plates installed.   I actually better double check.
I suppose try it on a scrap piece and you could always go 1-1/4" if needed.
Xam
  • Last login:July 18, 2011, 11:16:45 pm
  • " Oh my heavens; good gracious. Cro-Magnons."
« Reply #4 on: June 07, 2007, 11:51:51 pm »
I went 1 1/4" on my joys and 1 1/8" on my buttons. I think 1 1/8 would have worked fine on the joys.
Xam
Can't talk to a psycho like a normal human being.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #5 on: June 08, 2007, 01:55:32 pm »
IIRC:
The u360 without a restrictor under a full 3/4" panel needs a bigger hole to hit the full range.  A super, competition, p360, and atari/midway/happ 49-way are the same.
Routing decreases the needed hole size for full range of course.  Getting the u360 with restrictor plates does the same.
Robin
Knowledge is Power
miles2912
  • Last login:October 31, 2019, 05:30:24 pm
  • My first Home Game. Fairchild System F.
« Reply #6 on: June 08, 2007, 07:03:14 pm »
I just drilled a hole in a scrap piece of MDF and checked travel.  1.25" worked for me.
Don
  Scratch built upright MAME Cab
ArtsNFartsNCrafts
  • Last login:October 12, 2020, 09:22:50 pm
« Reply #7 on: November 13, 2007, 07:47:51 pm »
I know this is an old thread, but my question is within the topic at hand, so why not?
I have a magstik plus, which has a pretty short throw, and was wondering if anyone knew what size i needed to drill the joystick hole.  right now i'm using the standard bat top.  I may switch to a balltop..
  • Last login:November 13, 2025, 08:40:37 pm
« Reply #8 on: November 13, 2007, 07:52:53 pm »
I still drilled a 1.25" hole. You'll need a hole that size when you decide to replace the magstik+ with a better joystick.
 ;) I kid! I kid!
ArtsNFartsNCrafts
« Reply #9 on: November 13, 2007, 07:58:44 pm »
hahaha.  It works for me, and I switch between 4 and 8 way enough to justify using one....i suuuuck if I play 4-way games without restriction (which might suggest that I plain suuuuck regardless, but oh well).
