Author Topic: Does anyone know the pot value of the Xbox analog sticks?  (Read 3061 times)
DarkBubble
« on: June 02, 2007, 09:50:16 am »
Ive got a few projects I'm mulling over and can't seem to find the potentiometer values anywhere.  I haven't had time to open up one of my pads, but I'm not even sure if they're labeled.
  • Last login:February 01, 2026, 01:32:52 pm
Re: Does anyone know the pot value of the Xbox analog sticks?
« Reply #1 on: June 03, 2007, 02:02:20 am »
All the xbox wheels use 5k pots... it's a safe bet that the analog sticks are 5 k as well.
DarkBubble
« Reply #2 on: June 04, 2007, 09:52:16 am »
EDIT:
I know that most wheels allow for something around 200-270 degrees of motion on the wheel itself.  The sticks don't move that much.  I'm sure that they're using gears or pulleys to compensate for the difference.  If I ever mess with wheels, I'll just have to get the ratio figured out before I go gear shopping.
« Last Edit: June 04, 2007, 04:56:20 pm by DarkBubble »
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
« Reply #3 on: June 05, 2007, 09:27:37 pm »
Ok, someone needs to change the title of this thread.  I was thinking something *totally* different then the previous posters.
DarkBubble
« Reply #4 on: June 06, 2007, 11:27:17 am »
Ehhh, there's one in every crowd, I tells ya!   :laugh2:
« Reply #5 on: June 06, 2007, 11:37:46 am »
The stick pots would definitely be different, particularly since there would be more than one of them, I'd assume.  A wheel would only need one, I think, unless you're talking about analog sticks on the wheel housing or something.
« Reply #6 on: June 07, 2007, 06:31:45 pm »
How do you get that?  A wheel moves from full left to full right as far as the game console is concerned.  This 270 degree thing has nothing to do with it since when the wheel is as far as it'll go to the left, then it's the same as pressing the analog stick as far as it'll go to the left.  The wheels I have all use 5k pots on the wheel so it's a safe bet.  Pedals would use the same btw, they just use resistors to "cut-off" the top or bottom halves respectively.
« Reply #7 on: June 07, 2007, 11:43:11 pm »
Left to right is only one axis.  A stick has two, usually one pot for each axis.
