Author Topic: Mamewah 1.62 Issue generating list  (Read 1283 times)
Squeeky
  • Last login:February 17, 2012, 04:10:56 pm
    • Makre $220 for Free, Follow My Tutorial
« on: May 25, 2007, 06:03:27 pm »
5/25/07 5:18:09 PM Keyboard enabled
5/25/07 5:18:22 PM List generation started...
5/25/07 5:18:23 PM Error: 76 Path not found in MsgExecCmd
5/25/07 5:18:23 PM List generation aborted
I have checked command.com is in both c:\ and c:\windows
any other input?
patrickmaher
  • Last login:May 30, 2009, 06:45:05 am
    • Patrick Maher
Re: Mamewah 1.62 Issue generating list
« Reply #1 on: May 25, 2007, 06:43:00 pm »
You might try doing what is suggested in this post from the MameWah forum.
Not sure which version you are using but under Windows 2000/XP you should see Environment Variables under the advanced tab in the system properties.
Edit -
If you follow that thread you may also find this post helpfull. You might try using 'rom_folder' just to see what happens.
« Last Edit: May 25, 2007, 06:52:14 pm by patrickmaher »
