November 30, 2025, 04:34:16 am
Ok i just noticed that a big IC has a crack in its casing could that be it?
That might be your video driver chip. Either way, unless this is an expensive board, that chip being cracked makes it a parts board to anyone but a really good solderer, IMO.
The main video chip is stamped:Rev 2 PCB Rev 3 PCB Rev 5B PCB------------------------------------------------------------XILINX P & P P & PXC4310 Marketing MarketingPQ160C 5380 AJ001 AT001PC5380-9651 5380-JY3306A 5380-N1045503APROTO AKI9749
Those pins are super close together..with solder paste you may bridge a connection. You could try it but you might want to put the solder paste on with a toothpic or something small and use little tiny amounts. Solder paste has a tendency to spread out. But all in all if you use small amounts it shouldn't wonder off the solder pad.
