Author Topic: Touch Screen performance with long VGA and serial cable??  (Read 4059 times)
squirrellydw
« on: May 21, 2007, 06:13:10 pm »
Does anyone know if the performance of a touch screen will be affected if I use a long VGA and serial cable?  My guess is it will be about 20 feet at the most.  The reason I ask is I would like to mount my touch screen on the wall and have the case as small as possible and I could but the computer with my stereo.  What do you guys think?
sorry if this is in the wrong forum
I b**ch. People listen!!
BobA
  • What Me Worry?
Re: Touch Screen performance with long VGA and serial cable??
« Reply #1 on: May 21, 2007, 06:31:18 pm »
RS232 is dual voltage and can be run a max of about 150 feet so it will be no problem.   The VGA is very much dependant on signal quality for analog so use the best cable you can for extended runs.  Projector and other units are quite often run on 10 to 20 meter cables for video presenations in auditoriums.  So 30 to 60 feet is commonly done.  20 feet should be no problem.
squirrellydw
« Reply #2 on: May 21, 2007, 06:37:23 pm »
thanks but what is RS232?
miles2912
  • Last login:October 31, 2019, 05:30:24 pm
  • My first Home Game. Fairchild System F.
« Reply #3 on: May 21, 2007, 08:48:13 pm »
RS232 is a serial cable.  Hardly used any more.  I have a 100 foot VGA cable run at an office to a plasma tv.  Works fine.
  Scratch built upright MAME Cab
squirrellydw
« Reply #4 on: May 21, 2007, 09:39:11 pm »
cool thanks, I just measured and will need about 35 to 40 feet total.  Any difference in using a VGA vs SVGA cable?  Newegg has both
« Last Edit: October 10, 2007, 09:33:11 pm by squirrellydw »
BobA
  • What Me Worry?
« Reply #5 on: May 22, 2007, 04:37:34 pm »
The ones on Newegg that are called SVGA seem to be of a bit better construction.   For the best look for a cable that uses small coax for the analog signals. The tiny coax transmits signals cleaner then twisted pairs.  Your 30 ft should not require anything special.
ahofle
    • Arcade Ambience Project
« Reply #6 on: May 22, 2007, 04:53:51 pm »
Monoprice has really good cables for cheap:
http://www.monoprice.com/
squirrellydw
« Reply #7 on: October 10, 2007, 09:31:12 pm »
Hey  BobA, since you seem to know your cables, if you get a chance what would you recommend from Newegg or cablestogo?  I need a SVGA and a serial cable about 35 to 40 feet.  If you don't have time, I will pick one myself.
« Last Edit: October 10, 2007, 09:45:53 pm by squirrellydw »
squirrellydw
« Reply #8 on: October 10, 2007, 09:58:31 pm »
Newegg 19.99
Cablestogo 64.99
Any thoughts?  The 19.99 ones seem ok, the Arrowmicro website says they use mini coax
« Last Edit: October 10, 2007, 10:05:36 pm by squirrellydw »
ahofle
« Reply #9 on: October 11, 2007, 11:31:45 am »
« Last Edit: October 11, 2007, 11:35:22 am by ahofle »
Neilyboy
  • Last login:October 08, 2025, 08:19:14 am
  • what day is it...
« Reply #10 on: October 11, 2007, 11:43:54 am »
i second monoprice.com ive bought over 300 bucks worth of component video cable from them to run all over my house and I can tell you their quality is top!!
neil
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #11 on: October 11, 2007, 12:44:38 pm »
Does anyone find it odd that MonoPrice.com has different pricing depending on the number of units you buy?
This opinion was created from 100% post consumed information.
BobA
  • What Me Worry?
« Reply #12 on: October 11, 2007, 12:48:37 pm »
I'd go with the Newegg or Monoprice.   The Newegg specifically mentions using mini coax.  The Monoprice does not mention if it uses coax but it should not be a problem at 35 feet.
heffe2001
  • Last login:September 27, 2021, 04:05:23 pm
    • o'Brewery Brothers
« Reply #13 on: October 11, 2007, 03:21:32 pm »
Quantity Discount.  Even Newegg does it :).
Green Giant
« Reply #14 on: October 11, 2007, 04:15:05 pm »
From monoprice's website, under specs:
Double Shielded 3-Coax 4 Twisted Pair
Toxic Arcade, my first build
BobA
  • What Me Worry?
« Reply #15 on: October 11, 2007, 04:17:42 pm »
Good catch. In that case cheap is good.
squirrellydw
« Reply #16 on: October 11, 2007, 04:45:42 pm »
so that monoprice one is ok then?  anyone wanna find a 50 foot serial cable that is good from them?
thanks
Green Giant
« Reply #17 on: October 11, 2007, 05:02:30 pm »
thanks
Everything I have purchased from them is just as good as what you get from the overpriced monster cables at best buy.  They are probably made in the same place, just these come packeged in bubble wrap instead of a fancy package.
I even have my 50" tv hanging on a wall mount from them, really good stuff.
As for the serial cable, this should have what you are looking for.
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10212
NickG
  • Last login:September 27, 2025, 08:06:19 am
  • Dig.
    • My Projects Page
« Reply #18 on: October 13, 2007, 10:33:04 am »
HA-ha! I finally understand your post.  It's because the name is Monoprice (as in one price)
