Author Topic: Ms Pacman RF Board and Ground  (Read 2455 times)
JeepMonkey
  • Last login:July 13, 2012, 01:51:24 pm
« on: May 18, 2007, 08:47:11 pm »
I have a nonworking Ms Pacman that I have been troubleshooting.  In searching the internet, I have read from TwoBits and other sources that the RF filter board is not needed and recommens that it be removed.  After removing the RF filter board,I fired up the machine and everything started working.   :applaud:
The RF board had a yellow ground strap connected to it.  Do I need to connect this ground strap to the main board now that the RF filter board has been removed?  If so, where should I connect the ground to the main board?
Pins:  Theatre Of Magic, JP The Lost World, Revenge From Mars
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
Re: Ms Pacman RF Board and Ground
« Reply #1 on: May 18, 2007, 11:03:07 pm »
No, you do not need that strap.  The board has ground attached through the connector.  Removing that board fixes a lot of Ms. Pac's, I've found.
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
JeepMonkey
« Reply #2 on: May 19, 2007, 07:12:38 pm »
Thanks for the help.
