Author Topic: 8 ohm speakers to PC  (Read 5853 times)
urbecrisch
  • Last login:February 23, 2026, 07:26:24 am
  • I was the S**T back in '82
« on: May 17, 2007, 08:27:45 pm »
I'm maming a CAB that originally came with 2 8ohm speakers which were connected to the PCB board.  Since I've removed the PCB board and will be using a PC to rum Mame:
Is it possible to connect the 2 8ohm speakers to my PC audio?
If so, how?
Thanks.
BobA
  • What Me Worry?
Re: 8 ohm speakers to PC
« Reply #1 on: May 17, 2007, 09:02:53 pm »
If you have an  PC with a sound card with an amp built in you can connect direct but with most on board sound you will require an audio amp.
urbecrisch
« Reply #2 on: May 17, 2007, 10:27:13 pm »
So if my audio inputs are on board to the MB I don't have a built in amp.  Are there any audio amps that you can suggest (cheap) that I can use for my PC?
Zebidee
  • Last login:Yesterday at 08:33:57 pm
« Reply #3 on: May 18, 2007, 05:55:39 am »
Try an old stereo system amplifier.
BobA
  • What Me Worry?
« Reply #4 on: May 18, 2007, 08:52:55 am »
There are many options available
The prefered method is to make your own from the insides of a 2.0 or 2.1 pc speaker set.
or you can
Use a home stereo amp from thrift shop.
or
diy
kit
Kit
Buy premade
« Last Edit: May 18, 2007, 08:55:01 am by BobA »
mountain
  • Last login:March 06, 2026, 07:42:38 am
    • Mountain Jukeboxes
« Reply #5 on: May 18, 2007, 09:07:27 am »
Hit the garage sale scene and find a pair of computer speakers cheap. I have found several pair this year any where from .25 cents to $2.00.
urbecrisch
« Reply #6 on: May 18, 2007, 09:27:41 am »
I found this tutorial that looks good. Are there any other good step-by-step websites anyone can refer me to?  Also, is this speaker hack as easy as it looks?  Thanks.
http://www.retroblast.com/articles/speakers.html
BobA
  • What Me Worry?
« Reply #7 on: May 18, 2007, 11:45:45 am »
It is as easy as it looks.   There are a few things to consider.
1.  The mod you are looking at uses a set of speakers with a remote volume contol.  If you do not get a remote volume control you will have to hack your amplifier board to remote mount the volume pot or have it accessable in your cabinet.
2.  Oscar contols (mirror) has a mod to add a remote volume control that does not require changes to the amp.
    Link Here
