Author Topic: wg4600 no control over brightness....  (Read 1681 times)
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
« on: May 17, 2007, 02:51:53 pm »
subject line says it all...
 pulled and check the pot on the neck pcb
 checked r 419 and r 418
Ken Layton
  • Guru
  • Technician
Re: wg4600 no control over brightness....
« Reply #1 on: May 18, 2007, 12:22:30 am »
The SCREEN pot on the neckboard rarely goes bad. It's the pot on the video interface board ("Black Level Control") that goes bad all the time.
cw
    • The Cab
« Reply #2 on: May 18, 2007, 03:18:21 pm »
pot was replaced with the cap kit...
Ken Layton
  • Guru
  • Technician
« Reply #3 on: May 18, 2007, 07:27:09 pm »
And you adjusted the black level control?
Did you resolder all the bad solder joints on the monitor main board and the daughter boards?
Did you swap the video interface board with one from another 4600 series monitor to isolate the problem to that board?
cw
    • The Cab
« Reply #4 on: May 18, 2007, 09:25:34 pm »
yes
yes
yes
thanks for the help ken.... this one is driving me nuts
