Author Topic: My last (?) 4p modular panel review?  (Read 1614 times)
vidmouse
  • Oop! Ack! Thppphbt!
    • Vidmouse's Arcade
« on: May 17, 2007, 02:47:43 pm »
Ok, took some input from a lot of folks and
realized also that I could move my P1 and P2 controls
closer to the center... I'm not using a trackball
mounting plate so there shouldn't be interference.
Also thought about using my Logitech Attack 3
joystick if I needed one w/ a top fire button
(otherwise, ignore that on the photo)... it would only
connect "as-needed" via my USB port mounted in front.
This way I found more space to keep from angling joys...
not that that's bad, but as I look at it w/ the wing modules
(removeable), there should be almost-equal spacing, good
enough for Smash TV...   :dunno
Comments?
  • Last login:November 25, 2025, 07:49:55 pm
Re: My last (?) 4p modular panel review?
« Reply #1 on: May 17, 2007, 03:17:09 pm »
Curious how the wings can maintain stability.
Layout somehow looks crowded, but the more I look at it - it looks ok.
ahofle
    • Arcade Ambience Project
« Reply #2 on: May 17, 2007, 03:33:26 pm »
How are you going to mount your trackball without a plate?
DaveMMR
« Reply #3 on: May 17, 2007, 03:44:50 pm »
It can be done, just a heck of a lot more work involved.
