Author Topic: Saving volume changes in Midway games?  (Read 1421 times)
MartyNg
  • Last login:April 26, 2014, 11:37:48 am
« on: May 16, 2007, 08:28:30 pm »
My volume settings don't seem to save in Midway games such as MK and NBA Jam. Every time I quit the game and go back in, I have to crank the volume all the way back up again. Is there any way to save all midway game settings at max volume? Thanks!
  • Last login:December 16, 2025, 04:07:15 pm
Re: Saving volume changes in Midway games?
« Reply #1 on: May 18, 2007, 08:37:31 am »
None that I can find.
shorthair
« Reply #2 on: May 18, 2007, 02:43:44 pm »
If you're using Mame32, when you change volume in-game, it only temporarily over-rides the settings in the GUI. You have to set it from GUI for it to be permanent.
MartyNg
« Reply #3 on: May 19, 2007, 09:35:16 am »
I probably should have pointed out that I'm using command line MAME with Mala as a front end. Thanks.
RetroBorg
  • Last login:September 15, 2025, 06:25:47 am
« Reply #4 on: May 20, 2007, 04:37:10 am »
Can't you just create an ini file for each game and set the volume there?
### Mame CORE sound options ###
samplerate 44100
samples 1
resamplefilter 1
sound 1
volume 0 (just alter this to the desired level)
