Author Topic: How to get rounded corners on Control Panel  (Read 3469 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« on: May 16, 2007, 05:59:22 pm »
I am in the process of building up my arcade I am building the control panel. I have a router and router tool piece set but have no woodworking skills and have never used one of these things before. I have provided a picture of what I want to achieve which is a rounded edge on the 4 corners of the C/P.
Re: How to get rounded corners on Control Panel
« Reply #1 on: May 16, 2007, 07:02:34 pm »
I trace out the corner using a round flat object (lid, tuna can, whatever), cut it with a jigsaw and smooth it with a sander.
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #2 on: May 16, 2007, 07:12:27 pm »
What Lew said or if you want your corners to be uniform in size and shape make a single corner template and use your router and flush trim bit to trim each corner with the template.
If your control panel is to be MDF then use lew's method. MDF sands very easily so getting the corners to the desired radius would only take a few minutes.
It's 9am. I'm calling it a nite.
Marky_1979
    • Personal Webspace
« Reply #3 on: May 16, 2007, 07:29:15 pm »
Cheers guys i'll try that
Chris G
« Reply #4 on: May 16, 2007, 08:02:56 pm »
Probably goes without saying, but do a practice run or two before you go after your CP.   :cheers:
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #5 on: May 17, 2007, 05:31:42 pm »
Here's a thread where I described one more way to put accurate curves down:
http://forum.arcadecontrols.com/index.php?topic=65454.0
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
