Author Topic: Opinions on how to secure a joint on a racing setup!!!!  (Read 1849 times)
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« on: May 16, 2007, 03:57:11 pm »
Opinions on how to secure a joint on a racing setup!!!!  Hey guys I am putting together a racing setup using this kit playseats.com, very nice setup except one small issue.  The hinged joint where you attach the steering wheel, i have this as tight as possible but the joint has some play if you jerk on the wheel of about a quarter of a inch, the setup has 1 big bolt with a washer running into a tack welded nut on the other side.  I'm trying to lock this joint into place would you guys recommend a lock washer or some kind of epoxy etc to make this permanent, i do not care if the joint moves again i have it where I like it.  Just looking for some help
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
Re: Opinions on how to secure a joint on a racing setup!!!!
« Reply #1 on: May 16, 2007, 06:27:54 pm »
Roach clip.  Putting it on the CP will cause a burn on the art.
TOK
  • The Game Always Wins
« Reply #2 on: May 16, 2007, 08:15:57 pm »
I'm looking at the picture on the web page to see what is moving... Is the whole shaft that supports the wheel platform the part that has the slop in it (the part that lets you move the wheel further/closer)? If so, I'd suggest wrapping it in plumbers tape for a non-destructive fix. Just wrap until you have an interference fit, slide the wheel shaft back into the base and tighten that clamp down.
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
« Reply #3 on: May 17, 2007, 09:06:01 am »
Not so good, you'd have to hold it while steering/shifting.
I prefer one of them ciggerette holders like Hunter S Thompson used to use.
Then I can just keep it in place puffing away with no interruptions.
As for the slop in the steering wheel, why not try the washers?
If they don't work out remove them.
A picture would help, I don't see the kit at the link you provided.
« Last Edit: May 17, 2007, 09:11:28 am by CykoMF »
divemaster127
« Reply #4 on: May 17, 2007, 10:20:38 am »
Here is a picture the plate the steering wheel hooks to is where I have the slop im trying to tighten it down...a lock washer, maybe a ribbed washer or some lock tight what do you guys think
thanks
dm
rovingmind
  • Last login:October 17, 2023, 11:13:48 pm
  • If you only knew the POWER of the Dark Side
    • rovingmind
« Reply #5 on: May 17, 2007, 01:29:31 pm »
WELD IT
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHHH!!!!!
divemaster127
« Reply #6 on: May 17, 2007, 01:40:35 pm »
I'm trying to avoid that the whole thing is built & wired it would be a ton of work to take apart for welding, plus this is aluminium tube I do not have that kind of welder
thanks
dm
rovingmind
    • rovingmind
« Reply #7 on: May 17, 2007, 01:52:39 pm »
epoxy weld then?
threadlocker would just lock the nut itself.
_) (V) (-)
« Reply #8 on: May 22, 2007, 08:13:10 am »
What about one of them flat roller bearings?
I don't know the exact name of them are but they look like a washer with BB's around the middle. (You'd see them under turntables or desk chairs)
This would give you a spacer that also rotates smoothly.
NickG
  • Last login:September 27, 2025, 08:06:19 am
  • Dig.
    • My Projects Page
« Reply #9 on: May 22, 2007, 11:53:49 pm »
Maybe you can drill an additional hole all the way through the rotating joint surfaces and stick a cotter pin or an additional bolt through it to lock the position.
