Author Topic: CP with game pads  (Read 1280 times)
lilspanisheddie
  • Last login:January 31, 2008, 03:21:02 pm
CP with game pads
« on: May 14, 2007, 03:12:15 pm »
I am getting closer and closer to building my cabinet and I was wondering about controllers.  I have plans on building a 2 person CP with trackball, but I also love playing the 4 player games.  Has anyone set up MAME with a CP for players 1 & 2 and then gamepads for players 3 and 4?
ahofle
    • Arcade Ambience Project
Re: CP with game pads
« Reply #1 on: May 14, 2007, 03:16:44 pm »
Sort of...I have a 3 player control panel with two USB female sockets on the front of the CP box for console games (or a 4th player in Gauntlet if necessary).  Works great!  If you plan on doing any console emulation, especially N64, then I would definitely go with USB jacks.
« Last Edit: May 14, 2007, 03:19:39 pm by ahofle »
lilspanisheddie
« Reply #2 on: May 14, 2007, 03:50:47 pm »
Does this mean you are able to have 4 players playing at once?  3 on your CP and 1 one a gamepad?
Instead of that adapter couldn't I use a hub on either side of the cabinet so that a gamepad could be plugged in on the side?  Does this make sense?
ahofle
« Reply #3 on: May 14, 2007, 03:54:55 pm »
Yes 4 players at once.  You can do 3 on the CP and 1 with the pad (or 2 on the CP and 2 with pads if you configure MAME correctly).  You could definitely use a USB hub, but where would you mount it?  The nice thing about the jacks is that you only need to drill a small hole and screw them in instead of cutting out a perfect square piece to mount a hub.
