Author Topic: Rules for Quote FU?  (Read 3952 times)
bfauska
Rules for Quote FU?
« on: May 09, 2007, 12:43:46 am »
You can only clip from the ends of the quotes. No cutting stuff out in the middle, and no adding stuff.
I recently read these words and was confused by them.... it happens a lot.  I am curious if some sensei can enlighten this grasshopper.  Does the proclamation above simply mean that it is not good clean quote fu if we remove words that fall somewhere between the first and last word of the quote?  I suspect that I took part of it to mean that we shouldn't use quotes from the middle of a post and now that is not what I am seeing anymore.  Maybe I don't need clarification after all, but I would love to hear some other quote fu wisdom.
shorthair
Re: Rules for Quote FU?
« Reply #1 on: May 09, 2007, 01:34:59 am »
Na, dude. Just like I said in that thread to horseboy. Everything's fair game except for adding words. (Not adding anything, as horseboy said.) Quote fu. Cute.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #2 on: May 09, 2007, 06:36:36 am »
Uh, shorty, you can't make sense using a regular post, don't try to play with the big kids ...
Working: Not Enough
Projects: Too Many
Progress: None
« Reply #3 on: May 09, 2007, 07:42:07 am »
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
« Reply #4 on: May 09, 2007, 11:08:21 am »
Quote from: saint
saint is all powerful.
Apparently he is.
« Reply #5 on: May 09, 2007, 11:09:06 am »
shardian
  • Trade Count: (+23)
« Reply #6 on: May 09, 2007, 11:17:15 am »
If there are no rules to quoting in the political world, why should there be here? ;D
« Reply #7 on: May 09, 2007, 11:19:47 am »
No rules means we can do anything.  Sometimes, I like to stick my fingers under my armpits and then I smell them like this.
horseboy
« Reply #8 on: May 09, 2007, 11:20:01 am »
shorthair- You are wrong. You added punctuation that wasn't there. Cheater.
bfauska- Here is the deal. We will take this gem as an example...
Perhaps, one of these days, some of you will start asking questions before your penis gets in the way. (Regardless, I'm enjoying my time.)
Now we can get rid of that first part as it probably won't be needed. YOu will be left with...
From there you can clip off more from either end or both ends to make the sentence mean whatever you want. Such as...
or...
or both ends...
But you can't take out certain words just to make it work better. Such as...
your penis gets in Regardless
or...
some of your penis gets in the way. (Regardless, I'm enjoying my time.)
No adding stuff or mixing up words obviously. You are getting into a mangle if you go that route.
So, ya, just clip from the ends, not the middle, and don't add anything. Even punctuation
Rarely, but sometimes it is acceptable to clip from the middle if you add an ellipsis. This is highly discouraged, and is usually reserved for the beginners or the elderly.
you will start... your penis
Quote from: saint
Apparently he is.
Chris G
« Reply #9 on: May 09, 2007, 11:20:51 am »
I would never add anything not originally written or completely hack something up.  I'm pretty sure I'm guilty of clipping out middle sections, but that can happen in the midst of Cooperative Quote Fu.
May I suggest another new term for this discussion: Quotiquette
shardian
« Reply #10 on: May 09, 2007, 11:22:55 am »
penis and terms such as cutting, snipping, clipping, etc. should never be mentioned in the same posting. It is a man rule - look it up. ;D
horseboy
« Reply #11 on: May 09, 2007, 11:23:38 am »
Touche
Quote from: saint
Apparently he is.
shardian
« Reply #12 on: May 09, 2007, 11:31:23 am »
Sometimes I do that, what is your point? At least make up something that is a false claim. ;D
EDIT: now the quote looks much better. ;D
« Reply #13 on: May 09, 2007, 11:31:52 am »
Damn my intuition.
« Reply #14 on: May 09, 2007, 11:38:44 am »
penis and cutting, snipping, clipping, etc. should be in the same man - look it up. ;D
I always find it amusing to see what you can make simply by subtracting words.   ;D
shardian
« Reply #15 on: May 09, 2007, 11:39:39 am »
Sorry, that one don't quite make sense. Good try though. ;D
« Reply #16 on: May 09, 2007, 11:40:59 am »
Yeah, they're not all gold, but it made me chuckle.
Glaine
  • Last login:April 24, 2013, 12:09:17 pm
« Reply #17 on: May 09, 2007, 11:53:18 am »
Should you draw the line if I was to create sentances using multiple proper quotes, similar to a note made from letters cut from magazines?
Example:
So, would you consider chopping up babies?
I'm pretty sure
I would
hack something up.
You heard it here, he stabbed a baby.
« Last Edit: May 09, 2007, 11:54:59 am by Glaine »
« Reply #18 on: May 09, 2007, 12:06:44 pm »
Probably vaild if the quotes are somewhat long... but taking 2-3 words from each post?  May as well not bother.
shorthair
« Reply #19 on: May 09, 2007, 12:13:44 pm »
cheffo: poor lad
On the rules: I disagree.
horseboy
« Reply #20 on: May 09, 2007, 12:23:31 pm »
That is why we do the quoting, while you supply the gold.
Quote from: saint
Apparently he is.
Chris G
« Reply #21 on: May 09, 2007, 12:30:12 pm »
Get in my belly!
shorthair
« Reply #22 on: May 09, 2007, 12:33:49 pm »
An economy of different sorts.
bfauska
« Reply #23 on: May 10, 2007, 12:20:51 am »
  • Last login:Yesterday at 03:00:01 pm
« Reply #24 on: May 10, 2007, 12:46:14 am »
I must've read about 50 posts from shorthair. Not 1 makes sense. The only logical conclusion is that he's from another country. Where you from shorthair?
shorthair
« Reply #25 on: May 10, 2007, 02:45:56 am »
1. I'm providing the currency.
2. in their use, they are recycling things.
lew:
I said I was alien.
danny_galaga
  • Last login:Yesterday at 08:18:34 pm
    • dans cocktail lounge
« Reply #26 on: May 10, 2007, 06:14:10 am »
 I'm not human.
shorthair
« Reply #27 on: May 10, 2007, 07:16:10 pm »
Hmhmhmhmhm, I remember that one...but it wasn't what I wanted, so I made up that last in hopes of it perhaps actually being said.
CheffoJeffo
« Reply #28 on: May 10, 2007, 07:22:36 pm »
Working: Not Enough
Projects: Too Many
Progress: None
