March 19, 2026, 06:21:25 pm
Most modern PC's monitors consider 31Khz or higher signal, wich given problems with using in a real arcade monitor. Modern video cards typically disable 15khz to prevent users from being used by the driver. This may get this pretty hard to get this to work on a Arcade monitor (even with Advanced MAME).
Nice addition. Thank you for your contribution.The previous paragraph, which you didn't write, made me scratch my head in confusion, though.
Most modern PC video cards output a 31Khz or higher signal, which is incompatible and in some cases harmful to real arcade monitors. As video cards evolved, 15Khz signals were abandoned by card manufacturers as they were no longer used by modern SVGA monitors. This can make it difficult to get standard video cards to display correctly on an arcade monitor.ArcadeVGA supports many arcade resolutions used by MAMEtm and other emulators, so you don't need any software scaling in most games. This results in games being displayed on your arcade monitor exactly as they were originally intended.Some resolutions used by certain games may not work on your arcade monitor, so these may need to be disabled with a resolution tool.
