Author Topic: Soft-15KHz - slim new tool for 15KHz on normal vga cards  (Read 1063856 times)
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re: Soft-15KHz - slim new tool for 15KHz on normal vga cards
« Reply #80 on: May 31, 2007, 04:02:31 pm »
So you couldn't run any real CGA resolutions like 320x240, 288x224, etc?
I didn't try it with Mame, Windows only.  Window would only allow those resolutions.
That's weird. Every resolution for whichever setting you chose in Soft15Khz should show up in Windows display settings or Quickres. So if you chose 15Khz in Soft15Khz, you should see 256x240, 321x240, 321x256 etc. etc.
SirPeale
  • Green Mountain Man
« Reply #81 on: May 31, 2007, 05:31:17 pm »
I couldn't use QuickRes because I didn't have a mouse hooked up.  But when I looked in display properties (all modes) there were only four resolutions listed.
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
« Reply #82 on: May 31, 2007, 06:01:09 pm »
The windows display panel will only display resolutions down to 800x600 in XP, and I believe 640x480 in 98. To access those lower, 15khz Mame resolutions, you will HAVE TO use a program like Quickres.
Well, you'll need it to manually change to those resolutions. You can always write specific ini's for your games that tell Mame what res to launch the game in.
SirPeale
« Reply #83 on: May 31, 2007, 06:07:47 pm »
I went into advanced options to display all available modes.
Joystick Jerk
« Reply #84 on: May 31, 2007, 06:53:54 pm »
It still won't display those lower resolutions in the windows display panel.
Trust me, you have to have something like Quickres to manually change to resolutions lower than 640x480.
JoyMonkey
    • JoyMonkey.com
« Reply #85 on: May 31, 2007, 08:25:44 pm »
The 15khz resolutions are all there in display panel on my XP (SP2) test machine  :dunno
Joystick Jerk
« Reply #86 on: May 31, 2007, 08:45:24 pm »
Weird, I can use them, but I can only manually change them via Quickres.
shorthair
« Reply #87 on: May 31, 2007, 11:26:02 pm »
Well, are any of you who have it working having any issues like I mentioned above (games not imaging and the monitor just making a sucking noise)? This happens with Pac-man with res set to auto, or 288x240. With the avga, auto works just fine for either orientation. Or the desktop flicker for SVGA or XGA?
SailorSat
  • Last login:October 11, 2025, 08:20:43 am
    • For Amusement Only e.V.
« Reply #88 on: June 01, 2007, 04:03:53 am »
Hm...
Even if your monitor couldn't sync to a resolution you should at least see something (even if its only white flashes from MAME's "Press OK"-screen).
As for brightness, the display should be as bright as with an ArcadeVGA.
For the flicker with interlaced resolution, well, that may change from chipset to chipset.
My Matrox Millenium (1st model) card flickers in 640x480, whereas my Radeons (neither the 7000 nor the 9200se) don't.
However you said you got these issues with an Radeon 7000 and an GeForce 6200, so I'm quite puzzled right now.
I'll recheck later with my 7000.
As for the resolutions, Windows should not display any resolution lower than 800x600 in WindowsXP Display properties (640x480 in 98/2000), and nothing lower than 640x480 in Windows Advanced Display. At least it doesn't for me ;).
« Last Edit: June 01, 2007, 04:12:53 am by SailorSat »
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
shorthair
« Reply #89 on: June 01, 2007, 04:03:37 pm »
SS: yeah, on either card, I get flicker at resolutions above VGA. Also, some resolutions won't display anything - the monitor just tries to sync but nothing happens - or the monitor just shuts down.
SirPeale
« Reply #90 on: June 02, 2007, 04:43:20 pm »
I swear, every time I start in on a project, my daughter wakes from her nap.  Today was no exception!
But I did sneak in a few moments to play with this before she did.  This time I hooked up a mouse, turned on QuickRes and tuned my resolution to 321x240.  Flicker gone.
Fired up Robotron.  F'n sweet!  So was Metal Slug, Bubbles and Defender.
Couldn't get Kymaera to launch, but I suspect a configuration issue.  It's quirky when paths aren't declared correctly.
rockmes
  • Last login:June 05, 2016, 09:41:38 am
  • Don't you love it?
« Reply #91 on: June 10, 2007, 03:20:14 am »
lm impressed with this software. just tried it with 15 khz 29" monitor and was using the lastest 9200 version of the ArcadeVga card , but now using Nvidia 6600 gt with recommended forceware drivers - i think 78.01 , and l must say it kills all over the ArcadeVga card . Of course l have a j-pac connect so the bios screens come up in split screen but once windows desktop kicks in all is sweet. lm using the 15 khz setting in the software and running 800x600 res with no flickering. the image is brighter and sharper and it also means l can play some of the lastest pc games which l couldnt previously. Thanks to the author ,bloody unbelievable stuff.
ahofle
    • Arcade Ambience Project
« Reply #92 on: June 11, 2007, 10:44:59 pm »
I don't understand how a 15khz signal from one card would be different than a 15 khz signal from another?  ???  How exactly does it 'kill all over' the arcadeVGA?
It's able to magically display interlaced video modes on CGA monitors without flickering? :laugh2:
Joystick Jerk
« Reply #93 on: June 11, 2007, 11:12:23 pm »
I guess he just means that now we can use much more powerful cards than what the AVGA offers.
rockmes
« Reply #94 on: June 12, 2007, 12:25:55 am »
Before you laugh try it out . lm telling you -no flickering, no bull.
l suppose lm using this res cos of my pc applications require it.
rockmes
« Reply #95 on: June 12, 2007, 12:28:36 am »
true .
But on my montior the current setup looks way better than with the 9200 AGP version of the ArcadeVGA. And dont get me wrong the ArcadeVGA rocks.
ahofle
« Reply #96 on: June 12, 2007, 01:16:37 am »
You are saying that with an ArcadeVGA/800x600/CGA monitor you get flickering and with Soft15khz/800x600/CGA monitor you get no flickering?  What you are describing is not possible and is probably going to mislead people.  Regarding the superior image quality compared to the ArcadeVGA, maybe you'd be kind enough to post some before and after pictures?  I'm genuinely curious to see what the difference is.
rockmes
« Reply #97 on: June 12, 2007, 04:37:08 am »
na l wasnt saying that you get a flickering picture with the ArcadeVga card at 800x600,
what l was trying to say after reading a few post ealier that lm not getting a flickery picture as some have been getting.
l seem to be getting a clearer and brighter picture with this software and video card and the drivers specified.
l will try and do some pics of the difference when l get the chance
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
« Reply #98 on: June 12, 2007, 10:31:50 am »
You have to remember that most of the flickering in high resolutions doesn't come from the interlace. The flicker occurs when neighbouring lines have a high contrast difference.
Most of the time this happens when you show computer images like the windows desktop. Modern 3D games and movies does not flicker much in interlace. Low res arcade games with doubled resolutions (without filter) flickers even less.
ahofle
« Reply #99 on: June 12, 2007, 01:18:09 pm »
Right.
I read his post as a comparison between the ArcadeVGA and Soft15khz and didn't want people to think they would not get flicker in Windows with Soft15khz compared to the ArcadeVGA.
shorthair
« Reply #100 on: June 12, 2007, 02:21:22 pm »
Yeah, this is how I read it, too. I don't know how he wasn't getting flicker at higher resolutions (which is why the tri-sync for the avga is handy, but apparently proprietary). I was, with different cards, as well as the desktop geometry being weird in XGA such that it'd be a 'scrolling' desktop. Changing to SVGA helped this, but not optimal cos I can do XGA. There are also other, slight differences, that arise cos the detailed timings, I would guess, are different.
Miketek
  • Last login:November 24, 2007, 11:54:10 pm
« Reply #101 on: June 13, 2007, 03:18:01 am »
I havent yet had the time to download this app and try it.
Is this considered to be better than Powerstrip in any way?
Here is the problem Im trying to solve:
Running via JPAC from a Geforce MX440 video card. Using Powerstrip with its default arcade res  "640x480i - arcade" (this defaults to 16khz which didnt not work for me, however when I set it to 15khz it works.. )
On this setting I can play the few games Ive tried just fine on my arcade VGA monitor (usually using Strider as a test Rom) BUT the windows desktop is horribly blurry, and Im loading the roms basically by memory out of my favorites folder in MAME32.
After some tweaking of resolution, I can get the windows desktop looking very clear, but then its split down the middle.. Only when I go back to "640x480i - arcade" and set to 15khz do I get a single usable screen again, which as I stated above looks fine once the game starts but is horribly blurry in windows (XP)
Will Soft-15khz or QuickRes work better for me in this regard than Powerstrip? Ill probably have some time later tomorrow to mess around with it some more, but any advice, suggestions to work with would be great! My goal = clear XP desktop without a split down the middle!
 8)
Joystick Jerk
« Reply #102 on: June 13, 2007, 03:36:32 am »
Powerstrip can probably do exactly what this prog does with sufficient tweaking, but this prog is dead simple to use. Install it and.... well, that's it really. Everything is done at the driver level, so you don't really have to tweak anything.
shorthair
« Reply #103 on: June 13, 2007, 03:37:48 pm »
 8)
Yeah, as JJ said...BUT:
1.it seems you're using powerstrip to force VGA resolution.
2. quickres is just an app that lets you select resolutions from the taskbar; it's not a driver or set of drivers.
3. we don't know what monitor you're using and what it's capable of. I'm not sure you know.
Miketek
« Reply #104 on: June 13, 2007, 08:28:03 pm »
I beleive I have to, without powerstrip I couldnt see a thing once windows booted ( I could see the split screen at post/bios etc with the Jpac set to 15khz and 31khz jumpers..
Here's a thread (with pics) I made on the monitor back in April when I first got the upright..
http://forum.arcadecontrols.com/index.php?topic=65253.msg655754#msg655754
It does work with the original Jamma board quite nicely, but via JPAC and Powerstrip I can only get a usable screen at 15khz and 640x480i res. As I stated above it works just fine when game roms are loaded, but at Windows desktop its very blurry.. with some tweaking I can get Windows in crystal clear, but then its split screen once again... I do have a drawer full of older Rage II era video cards, but then certain games like SmashTV, Strike Force etc lag like mad, so I want to stick with the Geforce if possible.
Will try the Soft15khz app tonight if I get the time!
Miketek
« Reply #105 on: June 13, 2007, 10:22:36 pm »
Well after alot of playing about with Soft-15khz and having similar results as with Powerstrip, I have found a very usable workaround to my issue of not being able to read anything on the Windows Desktop.. Or the MAME game list..
I just changed the default Font to Arial Black Bold 16 and everything is VERY readable now  :P
shorthair
« Reply #106 on: June 14, 2007, 02:49:34 pm »
That's what I thought. You're using an original equipment monitor, Do you know the resolutions it's capable of? Getting split screen is usually bad. My multi-sync auto-shuts down when this happens. You may be putting undue stress on your monitor.
shorthair
« Reply #107 on: June 20, 2007, 07:07:30 pm »
Update: Well, this program seems to be very hardware (video card, at least) dependent. On my PIII using a Gforce3 Ti200, I got regular native resolutions. However, on my new 2.8 P4 with an Nvidia 6200 unlocked to a 6700, I got the following very curious results (note, both computers are using XP SP2) :
First off, my Billabs multi-sync has various resolutions that many game resolutions fall under and the OSD displays them (ie: 640x224 for 240x256, 336x240, etc). In all games using soft-15 with the 6200, in the OSD I get 'user mode', with the timings at the bottom, and it turns out there are groups of games that fall under these, too. However, they're not all related by game resolution as is the case for the regular modes: for example, most 224x288 games are in the same group - except Jr Pac-man.
This is where it gets interesting. I noticed that in most games, the horizontal frequency shown in the OSD was 31khz - and often the vertical frequency being over 100! Even more interesting: I had my Monivision monitor hooked up to the other output, and expected it to turn off when loading games at native res. Not so. If got the same kind of image as with the Billabs -  and the exact same in a few cases, no geometry difference between the two - and scan lines just as with the AVGA. Hmmmm.
What is happening here? To note, there are other differences, of which I've expressed before: the AVGA does some kind of strange brightness thing at low and medium resolutions (and my monitor makes a whine) that I can't replicate in Mame with stretch, and isn't happening with soft-15, though soft-15 does seem to make it a little brighter. Although, while I find the brightness of the AVGA games entrancing, those in soft-15 are easier on the eyes, particularly the scan lines.
There are also some oddities: regardless of either card used, there are games that don't sync - the Billabs will make a syncing noise, or both monitors will be blank and Mame32 closes back to the GUI - though they're not the same between cards. I haven't tried regular mame in a little while but recall observing the same behavior.
I also re-emphasize that windows at 1024x768 gives a scrolling desktop on either computer.
SailorSat
« Reply #108 on: June 21, 2007, 12:30:24 am »
Hm...
Sounds like the 6200 doesn't output 15KHz, an all Modes are "doubled" to 31KHz. Then they would either be the doubled vertical resolution (i.e. 320x240 should be 320x480) or doubled refresh rate (~120Hz).
About the 1024x768... Yeah, actually the VISIBLE resolution is 1024x600, as it is simply not possible to display more lines without droping below 50Hz.
I don't know whats the problem with the "low-end" cards.
I know a GeForce2 MX can do interlace, as it does on DOS, and it did with older Detonator / ForceWare drivers.
However on the newer (66.93 and newer) drivers, all "cheap" (GeForce2 MX)  cards I tried can't do interlace, the "better" ones (GeForce2 GTS) do, although they both can do with the old drivers.
Sadly older drivers don't support custom resolutions.
However, you can checkout what resolutions you card is outputing if you take a look in the ForceWare, as there should be an "Advanced Timing" Button somewhere.
shorthair
« Reply #109 on: June 21, 2007, 03:14:10 pm »
Hm...
Well, it looks pretty much the same to me. This would apparently be a bonus: to get native-looking resolutions, people wouldn't need a monitor that goes below 31khz. Might be something worth looking into.
Somehow, the arcade VGA is able to. Along with that 'brightness' factor, this might be something proprietary.
Also, anything new on the development of 35khz and higher resolutions?...and on integrated video?
SailorSat
« Reply #110 on: June 21, 2007, 06:06:15 pm »
As for integrated video...
Radeon Express should work fine.
GeForce2Go or such could work, but right now never got hands on one.
Intel GMA is still in works. I should be able to add resolutions to the mode list, however I can't disable the "basic" ones.
Also I don't have a board with it.
As for new resolutions...
Right now the only 35KHz resolutions I can imagine of would be 800x600 @ 60Hz and 1024x768 @ 50Hz (all lines visible).
But I don't know of any game that needs it, so nothing happens.
As for native resolutions...
If you monitor can handle 120Hz, you could try the file attached.
BUT... real 320 * 240 will look quite bad on an 21" VGA Monitor, because of the small dot matrix. You will see quite large scanlines (larger than the "visible" lines)
*EDIT*
« Last Edit: June 21, 2007, 06:08:04 pm by SailorSat »
shorthair
« Reply #111 on: June 22, 2007, 01:42:37 am »
Yeah, when I say integrated I'm asking about Intel sets.
35khz and above: well, I do a lot of stuff in Windows still, plus I like to run front-ends and vector games at high resolutions. Both my monitors will do up to 1024x768. (One is an arcade monitor, the other is a presentation monitor.)
I tried an experiment and only loaded 31khz resolutions. This made all the games run at high refresh but still with native-looking scanlines. (I also tried it on my 21" PC monitor, and I recommend it to anyone using a PC monitor. You're right in that the scan lines are thick, but it's better than using Mame effects.) So, I guess this card is weird: it will output 15khz, but only to a select few games. Most run high refresh.
Also, I don't know what to do with that file.
SailorSat
« Reply #112 on: June 22, 2007, 10:52:24 am »
just save it in the same folder as soft15khz.exe and name it custom31khz.txt, then run soft15khz and click "install 31khz".
bout intel... yeah, a new board with a new chipset requires a new cpu and new memory and --- yeah, quite a big investment for "just" another driver :)
shorthair
« Reply #113 on: June 22, 2007, 05:12:30 pm »
Intel set: yeah, that is a big investment.
Oh. Okay, that's what I did in my experiment and forgot to mention it, but I wasn't sure that was what I was supposed to do. So, the card is weird, and it's like this:
1) if I load all three modes, it will display most games as native-looking resolutions with high refresh but a few will be at 15khz. There are a few games that just won't load: some are particular to my Billabs monitor, whereas some won't load on either monitor.
2) if I load only 31khz mode, it will display all games at native-looking resolutions with high refresh rates. The same ones still don't work, though a couple few that didn't, do now.
computarmann
  • Last login:February 20, 2014, 12:42:46 pm
« Reply #114 on: July 03, 2007, 08:44:14 am »
    I tried soft- 15khz with my laptop which has an nvidea geforce 5200 and emulators like epsxe look amazing on my sony pvm-2530. I'm using windows xp on the laptop and mame looks almost as good as advancemame on my usual desktop machine that is usually hooked to this sony pvm which has windows 98. I tried windows 98 using an ati all-in-wonder 7500 and the desktop as well as mame etc. looked more flickery. I expect windows to flicker some, but I don't understand why with the ati 7500 that mame flickers. I would like to use advancemame for mame and use windows for other emulators but The ati is just too flickery so I put my old voodoo 3500 back in just to use advancemame. The voodoo 3500 does a much better job of filling the screen out and seems to look more crisp on advancemame. Maybe support for voodoo can be added to soft- 15khz.
    Soft-15 khz is an amazing program and I run my laptop in clone mode and it does'nt matter what the desktop looks like because I just use the laptop display which appears normal at 800x600. Epsxe and zsnes look about as perfect as perfect gets with the resolution set to 640x480. I tried this program not expecting much but I was pleasantly surprised. I tried ccs64 and it was something to see a blue c64 screen in RGB.  :D
ARTIFACT
« Reply #115 on: July 10, 2007, 10:41:56 pm »
Would this improve display on my setup?
. Nvidia GeForce 4 MX
. S-Video
. 27" SONY Trinitron TV
... not SCART, not component... S-Video
Thanks for letting me know!
SailorSat
« Reply #116 on: July 12, 2007, 12:00:52 pm »
Try running ZSNES in Custom Mode with a 512x240 resolution, it will look even better :)
Most likely not, although I've never tried.
tba
  • Last login:July 21, 2010, 12:27:08 am
« Reply #117 on: July 13, 2007, 05:11:27 am »
first:
woo,  :cheers: i tried this program and it worked great on my old PII-400 with a 3DFX voodoo 3500 TV!
Thank you, now i just have to get my Nanano 29" monitor working right!
Second:
SailorSat: you are my new hero! ;) i love your program, love your Sig line and could stare at your Avatar all day, there is just something so sexy/evil about it!  >:D
keep up the great work! 8)
disaac
  • Last login:October 15, 2009, 05:16:29 pm
« Reply #118 on: July 13, 2007, 07:02:58 pm »
Crap I can't seem to get this installed on Vista 32-bit.  I follow the instructions but never get to see the lower resolutions in Quickres or Windows Display Properties.
Radeon 2600 XT - yeah vista and this card (Cat 7.6), I know im pushing my luck already.
I have a feeling its not making the correct entries into the Vista Registry as needed.
Anybody seen this?
Daniel
ARTIFACT
« Reply #119 on: July 14, 2007, 12:07:45 am »
awww :(
