Author Topic: WinCab newbie question  (Read 4607 times)
MPTech
  • Last login:January 05, 2025, 03:58:54 pm
  • UltimateArcade completed!
« on: May 04, 2007, 10:09:36 am »
Getting my PC setup in preperation for constructing my Juke.
I installed WinCab and when I execute it, I'm receiving this message:
FATAL ERROR
No songs found!
Check the Song Path setting in JUKEBOX.INI
So I scrolled down to the SongPath line and copy and pasted the path of the folder into the SongPath1 line and uncommented it (removed the # from the first position).
I still get this message, but I can see the title of the first song in that folder, under the error message.
What am I missing already??
OK, so assuming I persevere past this point, what configurations / tweaks have people added to their WinCab setups.
Thanks Guys!
MPTech
MPTech
   Better living thru technology!   ;-)
Chris
  • Moderator
    • Chris's MAME Cabinet
Re: WinCab newbie question
« Reply #1 on: May 04, 2007, 11:08:02 am »
Can you cut and paste the SongPath settings or attach your jukebox.ini so I can figure this out?
--Chris
--Chris
MPTech
« Reply #2 on: May 04, 2007, 12:25:22 pm »
I'll copy&paste it tonite when I get home.
I copied it from the path when I opened the file and pasted it into the .ini file.
Actually, below the error message, it shows the song title of the first song in the folder, strange.
MPTech
Chris
  • Moderator
« Reply #3 on: May 04, 2007, 01:22:04 pm »
Is it possible that all of your music files are WMA files?  WinCab only supports MP3, OGG and MIDI files so if a file with one of those extensions isn't found you'll get this message.
--Chris
MPTech
« Reply #4 on: May 04, 2007, 02:05:33 pm »
I'll bet that's it!   I just copied a CD I had to the folder, to test the setup.
 :notworthy:
I'll confirm, but I'm 99% sure that is the issue.
MPTech
MPTech
« Reply #5 on: May 05, 2007, 02:08:14 am »
Perfect!  That was it, DOH..............
Listening to some songs now and reading more on Wincab.
MPTech
