Author Topic: chassis number  (Read 1592 times)
chris79
  • Last login:September 07, 2007, 03:25:14 pm
chassis number
« on: May 03, 2007, 02:32:39 pm »
if you find the chassis number on your monitor, will that tell you what kind of monitor you have?  I used to think mine was a Electrohome, but I seen a chassis number on the back that has a WG then some numbers so i'm not sure now.
Ken Layton
  • Guru
  • Technician
Re: chassis number
« Reply #1 on: May 03, 2007, 06:21:18 pm »
I suggest you read this first:
http://forum.arcadecontrols.com/index.php?topic=62016.0
Then visiting the monitor id sites to see what you have.
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
Re: chassis number
« Reply #2 on: May 03, 2007, 10:51:33 pm »
I recently pulled a Nanao MS8-26SU out of a Golden Tee and it had a WGxxxxxx sticker on one of the metal sides.  Looked like it was factory applied, unless someone put a lot of glue on the back of one and stuck it on the chassis.  Did WG use a Nanao supplier at any point?  Or was this something done by someone sometime to maybe pass it off as a WG?
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
