Author Topic: Adobe illustrator Cs3 improvement?  (Read 1985 times)
The 414
  • Last login:December 12, 2018, 12:12:41 am
  • Im too ghoul for skool.
« on: May 02, 2007, 12:30:44 am »
Adobe Illustrator Cs3 has just been released. One of the important elements that can be used for restoring artwork is the live trace feature. Cs2 version was a pretty bad feature, it did not make it look close enough to the origional. How does CS3 compare? You decide. Personaly i think cs3 does a much better job then Cs2 did.
First the Png image fully vectored with little tweeking. only 8 colors enabled
Png image with full 256 colors enabled more tweeked.
the jpg version it was made from at 72dpi
Larger Versions
http://i32.photobucket.com/albums/d2/dc414/Gunrock.png
http://i32.photobucket.com/albums/d2/dc414/Gunrockfull.png
http://i32.photobucket.com/albums/d2/dc414/Gunrock.jpg
« Last Edit: May 02, 2007, 12:48:39 am by dc414 »
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
Re: Adobe illustrator Cs3 improvement?
« Reply #1 on: May 02, 2007, 06:00:43 pm »
So was all this done with live trace?  I'd love to see a comparision with the same image done in cs2 and cs3
The 414
« Reply #2 on: May 03, 2007, 12:34:55 am »
yes all of this was done in live trace. i did nothing by hand. all i did was select the image and hit live trace, selected inked drawing and thats about it except for changing color amounts. As for cs2 and cs3 il see what i can do.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #3 on: May 03, 2007, 06:01:53 am »
You should look at the result close up. I have always found that live tracing works fine when you look at it from the whole picture, but when you go close it looks like a mess.
zorg
« Reply #4 on: May 03, 2007, 07:25:23 am »
sacle it at 400% or more and let see if you still find it nice and sharp  :laugh2:
I'm on the planning stage
