Author Topic: LED Graphic Equaliser  (Read 3011 times)
More_Beer
  • Last login:December 04, 2013, 04:46:25 pm
« on: April 28, 2007, 09:08:50 pm »
This sound activated 72 LED tower mimics a graphic equaliser. It has four columns which respond to bass, midrange and treble frequencies. With its hyper sensitive circuitry, the LEDs will ascend to the most faintest of audible sound. It is ideal for your next DJ session or karaoke party. The unit incorporates an audio input RCA jack so it can be linked to your amp and modulated directly to  music. Complete with a stand the light equaliser can either be mounted vertically or horizontally and is supplied with a power supply.
Power: 12VAC  @ 1.7 Amps
Dimensions (excluding base) : 650(L) x 115(W) x 85(H)
Has anyone used one of these? I thought they would look great incorparated into a jukebox cab. Would I need to use the audio input RCA jack supplied, or can they detect the sound comming from the speakers?
Here's the link...
http://www.jaycar.com.au/productView.asp?ID=SL2946&CATID=21&keywords=&SPECIAL=&form=CAT&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=296
« Last Edit: April 28, 2007, 09:10:29 pm by more_beer »
Devospeed
  • Last login:February 25, 2011, 05:44:16 pm
    • devographx
Re: LED Graphic Equaliser
« Reply #1 on: April 29, 2007, 05:17:27 pm »
Nice find! Its not too badly priced either. Looks like something somebody on this forum could build though a little cheaper.
Fine Malt Graphics
More_Beer
« Reply #2 on: April 29, 2007, 08:04:13 pm »
Yeah I think they would look cool. I was planning on having 2 in my cab, 1 each side, making sure they fit in nice and flush so they look like they belong.
Lilwolf
« Reply #3 on: May 01, 2007, 02:12:54 pm »
For that price you could get a lcdwiz couldn't you?  I'm not sure if you could get the equalizer output though
More_Beer
« Reply #4 on: May 01, 2007, 08:53:22 pm »
lcdwiz?
Devospeed
    • devographx
« Reply #5 on: May 02, 2007, 07:54:22 am »
I guess he means Ledwiz from GGG. If I had the money I would purchase two of the graphic equalizers you mentioned, just easier to install.
Fine Malt Graphics
