Author Topic: Betson doesn't make 19" multi sync - Should I still go with D9500?  (Read 3308 times)
juggle50
  • Last login:July 18, 2024, 07:25:48 am
  • Your either on the bus or off the bus
Well,
Looks like Betson doesn't make a 19" multi sync monitor.  Is my only choice the D9500?  If so are they still having problems?
StephenH
  • Last login:January 09, 2023, 06:15:45 am
ahofle
    • Arcade Ambience Project
Re: Betson doesn't make 19" multi sync - Should I still go with D9500?
« Reply #2 on: April 17, 2007, 06:57:39 pm »
Whoa...I see that Billlabs now has a 24.8 multisync too?!?  Anyone know more about this (price, is it digital, etc)?  When you click on it it brings up a 27" multisync image though.  I'm guessing it's not digital because the 27" version has a board with all the adjustment pots on it.
"BL24C90T
24.8" 15~31 kHz Curved
CGA-EGA-VGA Autosync™
CGA/EGA/VGA Tri-Resolution V-Freq. 47~70 Hz
Adjustment Controls: Brightness, Contrast, H-Size, H Position, V-Size, V-Pos., Pincushion, Trapezoid, Rotation, Recall.
Sync: 15-pin D-sub male connector and/or 6-pin
(R, G, B, GND, H+V, V) connector
100~240 VAC, 50/60 Hz no isolation transformer needed"
flashdog
  • Last login:February 18, 2012, 06:10:58 pm
« Reply #3 on: April 17, 2007, 09:09:01 pm »
Betson - 24.8" multisync flatscreen  $ 359.95
               27"   digital multisync        $ 369.95
ahofle
« Reply #4 on: April 17, 2007, 09:51:23 pm »
Did you mean to type Billlabs?  Or does Betson have one too?  :dizzy:
Any idea if it's digital (ie. remembers settings between resolutions) or analog (pots required to manually change settings)?
flashdog
« Reply #5 on: April 18, 2007, 11:07:08 am »
                 http://www.betson.com
   Click the 27"monitor on main page, then go to show specials, lower left, monitors on last page of sale flier.
ahofle
« Reply #6 on: April 18, 2007, 12:54:47 pm »
LOL, it always amazes me when companies don't bother to properly advertise their stock on a website.  That monitor isn't even listed under their normal 'monitors' link, but buried in some obscure 'ASI Specials 07' link to a PDF file.
juggle50
« Reply #7 on: April 18, 2007, 01:18:45 pm »
Cool that Bilabs has a 19"
What is the difference between the BL19C91t and BL19BC1t?  Is it a digital monitor.  Can it do 800x600 there isn't much info on the site.
juggle50
« Reply #8 on: April 18, 2007, 03:27:52 pm »
Okay, I got the skinny from Bilabs - If they are correct.
The BL19C91t is an analog Multisync Monitor and doesn't support 800 x 600 resolution even in interlace
The BL19BC1t is a digital monitor but does not support CGA or EGA resolutions. only VGA and SVGA
So...does this mean that the WG 9500 is my only option to have a 19" multisync monitor that supports 800x600 resolution?
grantspain
« Reply #9 on: April 18, 2007, 03:32:55 pm »
can't rick at nieman displays help you out with a custom build?
juggle50
« Reply #10 on: April 18, 2007, 04:08:32 pm »
I don't really know anything about Neiman.  Are the D9500s supposed to be really bad?
ahofle
« Reply #11 on: April 18, 2007, 04:39:47 pm »
I think most of the bad press around here was with the D9200.  I personally haven't heard many people say anything about the newer WG models.  If a 19" digital multisync is really what you need, and WG has a warranty of at least a year, I would probably try it out.  I think most of the D9200 failures were pretty soon after purchase.
juggle50
« Reply #12 on: April 18, 2007, 05:13:26 pm »
Thank you
grantspain
« Reply #13 on: April 18, 2007, 05:30:01 pm »
i don't know about the new wg monitors,we stopped using them in the u.k after all the problems with u5000
if they are giving a 1 year warranty and its what you want then its worth a punt
