Author Topic: Does Daphne emulator work in WIN 98 SE?  (Read 2702 times)
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« on: April 14, 2003, 01:37:08 pm »
Does the Daphne emulator work ok in WIN 98 SE?   I saw a message that was saying that it will run jerky,  so I'm just trying to determine if I should upgrade my system to WIN XP Pro?  I don't want to upgrade to XP unless I have to?  I'm afraid of compatibility issue's with my current mame setup.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Does Daphne emulator work in WIN 98 SE?
« Reply #1 on: April 14, 2003, 01:48:41 pm »
It will work in win98... but you'll need a reasonably fast system and decent vid card.  It's just that it'll run better in w2k/xp system at the same clock speed/setup.
*shrug*...  the only way to know for sure is to try it and see if your setup responds well to LD games =)
Rampy
creatine28
« Reply #2 on: April 14, 2003, 01:53:18 pm »
Rampy
I'm using a 2 ghz Celeron system, I think the onboard video is pretty good, so I'll just give it a go!
Steve
creatine28
« Reply #3 on: April 14, 2003, 06:52:20 pm »
Another quick question,  has anyone made a Daphne .app for ArcadeOS?
Chris
    • Chris's MAME Cabinet
« Reply #4 on: April 14, 2003, 10:51:05 pm »
Daphne runs fine on my Athlon XP 2000+ on Windows 98SE.
--Chris
--Chris
Lilwolf
« Reply #5 on: April 16, 2003, 06:03:18 pm »
It runs fine... but not as good as XP.
I went from 98 -> XP on the same hardware and it seemed to run much smoother on XP.  But not enough difference for me to choose XP over 98..
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #6 on: April 16, 2003, 07:06:14 pm »
Unless you're talking about some specific reason for running 98 like you want to run analog+ you're crazy.  XP is far and away Microsoft's best OS attempt yet.  There's not even a debate.
Best Kid iPad Apps
Chris
« Reply #7 on: April 16, 2003, 10:29:10 pm »
Well, I have 98, and it runs well enough for a cabinet, so why spend the money to upgrade to XP when all you're running is emulators?
I wish DAPHNE used Allegro instead of SDL... then it would run in DOS, which is more stable than any other Microsoft OS...
--Chris
--Chris
  • Last login:Today at 01:32:52 pm
« Reply #8 on: April 16, 2003, 11:38:44 pm »
Because Xp is the most robust operating system windows ever made. It's lightyears ahead of 9x.  You don't HAVE to run it, but all of your helper apps (front ends, media players, ect) will get better performance in xp.  That is assuming you meet and exceed the minimum sys req. :)
