Author Topic: 2 Questions with pictures  (Read 1114 times)
urbecrisch
  • Last login:February 23, 2026, 07:26:24 am
  • I was the S**T back in '82
« on: April 15, 2007, 11:54:04 pm »
I'll get right to the nitty gritty.
1. What is this (PIC 1) and is it important to use?
2. How would I make this angle cut (PIC 2) on my CP?
Cheers!
destructor
Re: 2 Questions with pictures
« Reply #1 on: April 16, 2007, 01:07:34 am »
1. Door switch. If door is open no power to PCB, or power is for test game mode. You can remove this and connect wires from this switch.
NoOne=NBA=
« Reply #2 on: April 16, 2007, 01:15:27 am »
With the board stood on end on a table saw.
Set the rip fence 1/2" or so off the blade, and put the blade at the right angle.
You'll probably need to remove the blade guard to do it, so be careful.
Alternately, you could use a belt sander to do it.
