Author Topic: Are all power supplies created equal?  (Read 1324 times)
knave
  • Last login:October 15, 2025, 04:12:19 pm
« on: April 14, 2007, 01:17:59 am »
How different are the power supplies from various cabs.  Could I put my old Galaxian PCB into a modern (jamma) cab?  Would the PS work?
Do monitors each take the same basic power?
MaximRecoil
Re: Are all power supplies created equal?
« Reply #1 on: April 14, 2007, 02:34:10 am »
It depends on what your boardset requires for voltages. Some older pre-JAMMA boardsets had weird voltage requirements. A typical modern switching power supply such as you'll find in a JAMMA cabinet only supplies +12VDC, +5VDC, and -5VDC.
Most monitors require 120VAC. There are some exceptions, notably the Nintendo/Sanyo or Nintendo/Sharp monitors, which require 100VAC. Nintendo cabinets in countries such as the U.S. which have the 120 VAC @ 60 HZ power standard, include a 120VAC ---> 100VAC step-down transformer (which also functions as an isolation transformer).
Most older arcade monitors require an isolation transformer.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: April 14, 2007, 12:35:05 pm »
Galaxian and Pacman/MsPacman are an exception. They have a power supply section built into the gameboard and receive AC power from a transformer in the bottom of the cabinet.
If you wanted to use the Galaxian board in a Jamma cabinet you need two things: a Galaxian to Jamma adapter board and your gameboard must be modified/converted to use DC power.
