Author Topic: Got a Pole Position Arcade Machine Steering Wheel  (Read 1292 times)
janey
  • Last login:August 06, 2016, 02:36:23 pm
  • I want to build my own MAME / Hyperspin cab
« on: April 11, 2007, 05:05:01 pm »
and i'm trying to build a mame with car racing games.. How would i wire to get steering to work and also the shift ?/
 thanks
janey
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
Re: Got a Pole Position Arcade Machine Steering Wheel
« Reply #1 on: April 11, 2007, 05:23:26 pm »
you can hack the optics pcb from the wheel into a mouse.. for the shifter you can wire that into the mouse buttons or a gamepad or joystick....   when you do you might want to wire both of the positions into the same button seems to work better for shifting. For the pedal I replaced the 10k pot that comes on the pole pedal with a 100k pot. Then added another 100k pot to have another axis (windows does not seem to have a single axis joystick driver so you need two) then just hack those into a joystick port plug.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #2 on: April 12, 2007, 12:01:02 am »
You can connect the wheel to an Opti-Wiz, Opti-Pac, Mini-Pac, or Mouse Hack.  The correct pinout for the optics can be found in this thread:
http://forum.arcadecontrols.com/index.php?topic=64596.0
(click the pic to enlarge)
The shifter can connect to your Ipac, Keywiz, or whatever you're connecting your buttons to.
