Author Topic: MONITIOR HELP NEEDED PLEEEEEEEASE  (Read 3061 times)
midnitetoker
  • Last login:April 15, 2007, 04:23:49 pm
« on: April 09, 2007, 07:42:25 am »
hello there i have just recently been given a golden tee supreme edition arcade cabinet it has got a Hantarex polo 25 inch monitior in it. each time i plug it in to the mains i can hear sound coming through the speakers but there is no picture wot so ever. but each time i plug it in there is a blue spark coming out of the flyback transformer i have no idea if this normal or not. any help would be great or any links to solve the monitior issue thanks alot ?
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
Re: MONITIOR HELP NEEDED PLEEEEEEEASE
« Reply #1 on: April 09, 2007, 08:31:10 am »
no thats not normal.... can you see any cracks in the flyback? are the sparks coming from the flyback or the anode cap?
midnitetoker
« Reply #2 on: April 09, 2007, 08:33:31 am »
i can not see any cracks in  the flyback and the spark is coming from the red cable which is connected to the flyback ?
midnitetoker
« Reply #3 on: April 09, 2007, 09:50:11 am »
yes there a slight crack on  the top of flyback ?
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #4 on: April 09, 2007, 11:12:06 am »
Well...you need a new monitor.  You can't get new Hantarex flybacks anymore.
Unless someone has a supply somewhere, that is.
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
« Reply #5 on: April 09, 2007, 11:27:51 am »
Bob Roberts has the Hantarex Polo flyback and cap kit on sale for $23.00 right now....
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
midnitetoker
« Reply #6 on: April 09, 2007, 11:35:19 am »
would the monitior work if i was able to get hold of peplacemnt flyback ?
Jeff AMN
    • Gamer Theory
« Reply #7 on: April 09, 2007, 11:52:46 am »
That's almost impossible to say. You know what is keeping you from going forward, and $23.00 isn't a lot, so I'd replace the that part and see if anything else comes up.
midnitetoker
« Reply #8 on: April 09, 2007, 11:59:32 am »
thanks for all your help cheers
Ken Layton
  • Guru
  • Technician
« Reply #9 on: April 09, 2007, 12:43:30 pm »
Bob Roberts, Zanen Electronics, and R.H. Belam (www.belamny.com) all stock Hantarex flybacks here in the USA. In the UK, Suzo has them and Hantarex has a UK office too.
grantspain
« Reply #10 on: April 09, 2007, 12:58:34 pm »
make sure you quote the part number on the side of the flyback when ordering because some later golden tee had polo 2 in them
grantspain
« Reply #11 on: April 09, 2007, 04:03:59 pm »
just to add that i know a few chaps that can do visit repairs in the london area if changing the flyback is a bit beyond your skills
SirPeale
« Reply #12 on: April 09, 2007, 04:05:34 pm »
Isn't THAT interesting.  I've been told by the monitor tech @ East Coast Amusements that they were no longer available.
Unless I'm thinking of the MTC9000, is that still available?
Ken Layton
  • Guru
  • Technician
« Reply #13 on: April 09, 2007, 06:08:53 pm »
Many, but not all, Hantarex flybacks are available as reproductions/replacements also from the H.R. Diemen company in Spain (distributed in the USA by MCM Electronics).
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #14 on: April 09, 2007, 08:09:44 pm »
Ok- just before we throW it out..
With the monitor unpluggged... take a rag and spray it with WD40 wipe the red lead off.
Let it dry for a while and plug it back in... there is a possibility that all of the dust ... has carbonized and the cable is arcing out to the tubes aquadag... by the way make sure the anode does not touch the tubes aquadag.
Just in case you don't know, the aquadag is the area on the bell of the tube that is sort of a powder texture - usualy grey in color. It is actualy the return/ground path for the tube.
After that you will likely still not have a picture???
But check for an orange glow in the neck.
If it is there increase the G2/screen control on the flyback to see if the screen lights up.
BY THE WAY- I DO THIS STUFF EVERY DAY ALL DAY--- SO SOME SAFETY WARNINGS.
BE SURE YOU ARE CONNECTED TO AN ISOLATION TRANSFORMER
DO NOT GO ANTWHERE THE "BLUE SPARK' - THIS IS HIGH VOLTAGE LIKELY AROUND 25000 VOLTS.
ALSO, IF THAT SPARK IS PRESENT IT MAY HAVE KNOCKED OUT THE GAME- DISCONNECT IT FROM THE MONITOR DOING ALL THIS.
Ok after that if the spark, and you have an orange neck glow, and after you turn the G2 up you have a lit screen (this is called raster)
We can move onto other things.
Good luck
Rick Nieman
Rick@niemandisplays.com
www.niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
