February 04, 2026, 08:02:57 am
Mine tends to pull left when it starts slowing down. I don't thnk there's much you can do about it. I saw an old thread here once discussing it...
Quote from: grundle on April 08, 2007, 08:27:21 pmMine tends to pull left when it starts slowing down. I don't thnk there's much you can do about it. I saw an old thread here once discussing it...Probably for exactly the same reason..... The oil that is in the bearings when they arrive is way too heavy... Try what I said above and use a vey light machine oil. BUT Not WD40... The trick is to keep them clean. This should be done every three or four months. They also get better as they run in over the first few months of use.Best Regards,Julian (Fozzy The Bear)
