Author Topic: Power Supply Repair Guide ??  (Read 2482 times)
Luigi
  • Collecting/restoring cabs
« on: April 05, 2007, 04:02:48 am »
Due to the fact that we get more and more non-working switching power supplies I'd like to try and repair at least some of them. The errors are different: no 5V or 12V output, humming, etc.
Are there any repair/test guides available?
I'm speaking of such PSUs:
grantspain
Re: Power Supply Repair Guide ??
« Reply #1 on: April 05, 2007, 05:01:43 am »
because these are so cheap to buy no one usually bothers,depending on whether it blows the on board fuse or not points towards the problem
usually faults on these are bridge rectifiers,diodes,caps and power ic's/transistors
if its a case of missing voltage then just trace back the output
Luigi
« Reply #2 on: April 05, 2007, 06:41:52 am »
I did not realize that all folks here are millionaires ;)
A working PSU costs 40-50€ (here in Germany). We have at least 8 non-working units. If I could make 1 working out of two non-working I would be very happy :)
Concerning the lack of power...you are right. I should be able to just re-trace from the output point ....thanks for this little hint :)
grantspain
« Reply #3 on: April 05, 2007, 06:55:36 am »
i pay about 30 euro's for mine,where are you buying yours from?suzo?
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #4 on: April 05, 2007, 07:50:37 am »
Bad caps are often a cause.  I'd start there.
Luigi
« Reply #5 on: April 05, 2007, 08:04:03 am »
What makes me asking: how can I test a cap if it's ok or not ?   Do I have to unsolder it for testing or not? You will notice that my electronic abilities are not that good ;)
@grantspain: A german dealer has them for 39€. Even 30€ is too much to throw them all away. We have 3 Quadros in our collection. Each can hold 4 Jamma-PCBs and each PCB is served by a separate PSU.....I think now you understand why I want to repair our supplies ;)
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
« Reply #6 on: April 05, 2007, 08:46:57 am »
If you have a meter, it may have a cap tester on it.  Unsolder the cap and insert into your meter, setting it for capacitance (usually a C) and the next setting above your cap's rating.  If you get a short or open, it's probably bad.  If you get a value that climbs steadily, it's probably good.
You can eyeball the big caps to see if the tops look like they are bulging or cracked.  Sometimes just rubbing the top of them with your finger will pick up some oily residue that stinks.  This usually means that cap should me changed because it's blown or is thinking about it.  Smaller caps aren't as noticeable, unfortunately.
If you think a different part is blown, you can sometimes find your trouble area by looking at the back side of the board for discolorations like black or brown marks caused by heat.  While some parts do heat up naturally (hence the heat sinks) this can give you a starting point for testing parts.
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
Ken Layton
  • Guru
  • Technician
« Reply #7 on: April 05, 2007, 10:54:50 am »
http://randyfromm.com/amusements/techdept/    is a very good place to learn. Check out the power supply repair podcasts.
Luigi
« Reply #8 on: April 05, 2007, 12:04:50 pm »
..... because it's blown or is thinking about it.
Nice :D
Thanks for your hints. I'll take a lok at those casts.
I hope to get some experience about that stuff and (with a little help from the experts around) I will write a little tutorial then :)
