February 12, 2026, 01:01:02 am
Nice!Run that ink dry until it gets moved out.
Do you need to spray a protecting fixative or something on top? Doesn't it stick to plexiglass after a while?
Any way I can get a custom CPO for my DK cabinet printed by you? I'd happily pay some $$ for the time and effort?!?This is what it looks like (thus far...still work in progress):
I'm not really sure on this. After they are dry, they don't stick to each other. I would figure that spraying them with fixative would definitely help out alot. I will pick up a can and test out on one to see how it looks and how much durability it actually adds.
Quote from: shardian on April 05, 2007, 01:11:58 pmI'm not really sure on this. After they are dry, they don't stick to each other. I would figure that spraying them with fixative would definitely help out alot. I will pick up a can and test out on one to see how it looks and how much durability it actually adds.Warm up a copy and see if the ink wets a little. You're going to use it in front of a heat source.
Do you think regular old CLEAR COAT spraypaint would rectify the situation?
I don't have access to a laminating machine...does Kinkos do that kinda stuff?
Quote from: FrizzleFried on April 05, 2007, 06:26:12 pmDo you think regular old CLEAR COAT spraypaint would rectify the situation?How would laminating the stuff work? Would that mess things up?
If you're going to do it many times, you can get a low end laminator at Walmart for $25.
That's true, but I'm not sure he's going to get high end lamination for $3 a piece, either. The unit I have is easily good enough to do marquees that are going behind glass. CPs, no, probably not, not good enough quality.
Looks nice!! Where did you get the JK bezel? The only one I could find was low res.I've used Satin Crystal Clear on prints like these before and it held up pretty well. Maybe not good enough for a CP, but good enough for a marquee or bezel underlay for sure. I've used it on sideart as well. Might not hold up out in the elements, but has held up just fine in my gameroom.Wade
