Author Topic: Electrical problem on shinobi conversion cabinet  (Read 1609 times)
Crax
  • Hmm......maybe you should get that test still
  • Last login:March 12, 2022, 04:11:41 pm
« on: March 30, 2007, 10:38:05 am »
I took out my meter last night and went and checked some voltages on the shinobi conversion I have.  As seen below in the picture and the writing, I am supposed to get 5v on 4 of the pins, I got 5.08.  On two pins I am supposed to get 12 and I got 12.2...but then on the next two pins on the pcb I also get 12.2 and as far as I can tell I should have 0?  I get 0 on all the rest as it says.
Not quite sure what to do now as I can't really see anything wrong with the wires and am unsure why I am getting 12 on the next pins over.  As far as I can tell they aren't touching
JeepMonkey
  • Last login:July 13, 2012, 01:51:24 pm
Re: Electrical problem on shinobi conversion cabinet
« Reply #1 on: March 30, 2007, 10:46:01 am »
The coin mech switch isn't wired normally closed is it?  Put your meter on the coin mech 1 switch terminal, then toggle the switch.  Did the voltage level change?
Pins:  Theatre Of Magic, JP The Lost World, Revenge From Mars
Crax
« Reply #2 on: March 30, 2007, 10:56:33 am »
I didn't actually have any wires connected to the coin mech's when I ran these checks on the pcb.  Those wires were just loose but none were touching each other.  Would that make a difference?   ???  As you can tell, I am pretty new to this.  I'm at work right now, but any suggestions I can try hopefully tonight or tomorrow during the day.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: March 30, 2007, 10:58:09 am »
Your cabinet is wired with 12 volt DC coin counting meters.
Crax
« Reply #4 on: March 30, 2007, 11:03:50 am »
Yes, there is a counter in the cab as well.  So nothing to worry about then?  Should I be concerned at all that it's 12.2 V instead of 12?  Was just afraid of blowing something up yesterday on the board.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #5 on: March 30, 2007, 11:14:54 am »
Does the game work? If so, no worries.
NO MORE!!
Crax
« Reply #6 on: March 30, 2007, 11:17:52 am »
Couldn't tell you.  It was disassembled when I got it and the monitor isn't working.  I'm ordering a cap kit for the monitor but while I wait for that to ship, I figured I would go through the other stuff.  After reading that everything else was supposed to be 0 besides a few places, I was afraid of plugging in the board and blowing something up last night so I figured I better check here first.  As usual, that was a good idea.  Thanks to all so far.
RayB
  • There's my post
    • RayB.com
« Reply #7 on: March 30, 2007, 03:49:19 pm »
Your voltages are right in range.
NO MORE!!
