Author Topic: Pink Coin Inserts? (Coin Reject Buttons)  (Read 14244 times)
  • Last login:Yesterday at 03:55:38 pm
« on: March 29, 2007, 09:01:43 am »
The thread about the black and blue cabs inspired this because some people swapped out the normal red coin door inserts for blue ones to match their cabs (awesome touch!).  I was wondering if anyone knew if it was possible to get some pink ones?
« Last Edit: March 29, 2007, 12:34:50 pm by javeryh »
Dmod
  • Last login:July 12, 2012, 06:50:45 pm
Re: Pink Coin Inserts?
« Reply #1 on: March 29, 2007, 10:11:32 am »
Your best bet is probably to find a clear assembly and backlight it with a pink LED.
My Projects:
Suspended Animation Scratch-built Cab
Driveshaft Arcade Seat Platform
« Reply #2 on: March 29, 2007, 12:10:25 pm »
Hmm... that's a good idea - is it difficult to do?
Can I somehow swap out the lightbulbs back there for pink LEDs?
Any ideas on where to get a clear assembly?
Dmod
« Reply #3 on: March 29, 2007, 12:19:17 pm »
Here's a link which shows how to swap out the regular lights for LEDs.
http://joelsgadgets.com/Coindoorpage1.HTML
I just did a google on "PINK LED" and several links come up.  You may have to do some research to make sure they're going to be bright enough and will work with the Happ socket (assuming it's a Happ door).
The clear coin reject assembly looks like it might be harder to find.
My Projects:
« Reply #4 on: March 29, 2007, 12:34:25 pm »
Thanks - that's great info.  I did a Google search and found THIS but the color says "Amber" - it looks clear to me.  Check out the picture:
Any thoughts?
    • GroovyGameGear.com
Re: Pink Coin Inserts? (Coin Reject Buttons)
« Reply #5 on: March 29, 2007, 01:15:38 pm »
I'd be very surprised if you could find a pink assembly.  Clear is probably more likely, but may still be unavailable.
The problems are going to be similar to lighting translucent buttons in that the plastic will act like a filter.  If you try to illuminate a piece of plastic that passes only a narrow frequency of light (color) and you have an equally narrow light source (LED) the two better be a good match or there is a good chance that you will not only not see the color you expect, but you might see no evidence of illumination at all.
Placing a pink LED behind a red plastic assembly will stall cause the assembly to glow red, but only at the intensity of the red component in the pink LED.  IOW, you might as well light it with a red led, because that is all you'll see.
Clear will be the only option.
Kaytrim
  • I'm too nice a guy
« Reply #6 on: March 29, 2007, 01:27:29 pm »
Happ dosen't make a clear model.  Here is their product page.
TTFN :cheers:
Kaytrim
« Reply #7 on: March 29, 2007, 01:39:59 pm »
Randy - thanks for that info.  I didn't realize how these things even work!
Does anyone have any thoughts as to whether "Amber" means "clear" on the Happ site?  They also offer a pure "Yellow" one so I thought it would be odd if Amber also meant yellow - from the picture I posted above it looks clear, right?
« Reply #8 on: March 29, 2007, 01:43:46 pm »
It looks smoked, actually.
« Reply #9 on: March 29, 2007, 01:50:43 pm »
Nahh, it's just that it's a monochrome image.  Amber is a warm yellow that borders on orange, but not quite.    Think of the stuff they found the mosquito in, in Jurassic Park :)
« Reply #10 on: March 29, 2007, 02:07:07 pm »
Awww nuts.   :angry:
Thanks Randy - I was almost ready to order them just to find out.  Excellent reference too - I know exactly the color you are talking about.
I wonder how pink spray paint would work on the ones I have... I'd be losing the illumination but at least the colors would look right.  It is bugging me that everything on my cab will be pink or black except for red coin return buttons - they will stick out like crazy.
Maybe if we put our heads together we could think of a solution...
« Reply #11 on: March 29, 2007, 02:09:18 pm »
Get the clear ones and put a pink plastic film in them?
A plastics dye?
They make pink incadescents, maybe easier to try at first?
polaris
  • veni vidi congai
« Reply #12 on: March 29, 2007, 04:03:46 pm »
lighting gel
if you find a theatre suppliers you can ask for a free swatch book which will have pieces of gel (in all the pinks you can imagine) which would be big enough for a couple of coin slots. you might be able to get a swatch book straight from the manufacturers
« Reply #13 on: March 29, 2007, 04:07:01 pm »
These are great ideas - I need to find the clear coin reject assembly first though!  I've been searching Google all day with no luck...  Someone has to make some Happ sized ones so we can get crazy with the colors!!
Aurich
  • Last login:September 12, 2021, 01:34:32 am
« Reply #14 on: March 29, 2007, 04:09:56 pm »
I've never seen a clear coin button. :(
bfauska
« Reply #15 on: March 29, 2007, 04:11:34 pm »
I don't know if it worth the work to you or not, but you could always try to cast your own like the tron handle somebody on here is working on, then you could make it pink or clear.  Maybe this is a product that randy wants to make ;) If the EI buttons were a custom cast then maybe he has a supplier that would do a run of them.
Probably more trouble than anybody wants to go into though.
Later,
Brian
« Reply #16 on: March 29, 2007, 04:13:51 pm »
Who says it has to be an actual specific coin release button?  There has to be something simpler that can be made/used.  It's just a button.
bfauska
« Reply #17 on: March 29, 2007, 04:14:11 pm »
Actually if you don't yet have the coin door, or you aren't going to make it functional anyway, you could figure out a way to use the same type of button randy makes the cool coin-in buttons out of.  That would probably be easier to find with clear plastic, then you could either use gel, or dye it.
 :dunno
Seems like it could work.
L8R,
B
« Reply #18 on: March 29, 2007, 04:19:26 pm »
I do have the coin door already (the Small Single Coin Door from Happ).
How would I go about casting my own?  Is that complicated?  It sounds like it...
Tiger-Heli
    • Tiger-Heli
« Reply #19 on: March 29, 2007, 04:20:21 pm »
I haven't seen clear coin assemblies.
They used to sell blue plastic "dots" that you could put in the taillights of cars to get a pinkish-purple glow to them.
My point is I wonder what you would get illuminating the red coin buttons with a blue bulb or the red buttons with a blue bulb (and incandescents might work differently than LED's).
I thought I saw a website where someone tested various conbinations, but Google isn't helping me much yet.
« Reply #20 on: March 29, 2007, 04:33:47 pm »
That's really interesting... I wonder if there is a certain combination of Coin Assembly + LED that will give the illusion of a pink glow.  The coin assemblies come in Red, Yellow, Blue, Amber and Green and I'm pretty sure LEDs come in all sorts of crazy colors...  How could I figure this out?
« Reply #21 on: March 29, 2007, 04:38:02 pm »
Try shining a STRONG white light into a red one.  Maybe you can wash it out?
Tiger-Heli
    • Tiger-Heli
« Reply #22 on: March 29, 2007, 04:41:30 pm »
LED's come in many colors, and 194 automotive bulbs will work and come in blue and red.  I am thinking either red or amber with blue 194's might be closest, but that's purely speculation.
I found the site I was thinking of - looks like the closest he got was UV LED's to get purple -
http://www.blurbco.com/~gork/mamecab/coinleds/
linked from
http://www.retroblast.com/reviews/superbright.html
Minimal info here: http://www.notrica.com/arcade/coindoor.shtml
Also: http://www.arcadeparadise.org/arcade/ap3/lighting.html
http://retroblast.com/articles/coindoor.html
KevSteele tested a bunch of these, maybe you could PM or E-mail him and see if he still has the bulbs and return switches and could test some combinations for you.
polaris
  • veni vidi congai
« Reply #23 on: March 29, 2007, 06:27:08 pm »
that wont work i dont reckon, youll just get a bright red and a button too hot to touch  ;)
regarding making your own, bear with me on this as its a bit vague, but
my mate used to go to a design college they had a machine which could mold warmed perspex by a vacuum process, from my understanding you could carve a cube of wood suck a piece of perspex around it and you would end up with what your looking for ,a small raised 'groove' on the mold would facilitate easy cutting out of the actual coin slot.
if this doesnt make sense ill try and explain better. from what i understand its a cheap simple process as long as long as can you find the machine.
« Reply #24 on: March 30, 2007, 10:09:16 am »
Making my own sounds way complicated... I just don't have the experience to do something like that - or the access to any machinery.   :-\
I'm going to keep looking for a clear one though and possibly experiment with the stuff Tiger-Heli posted.
Also, what do you guys think of customizing the coin door a little to make the coin return doors pink as well as the frame around them and possibly the lock (as long as the paint wouldn't riun the actual locking mechanism)?
Kind of like this but prettier but you get the idea...
« Last Edit: March 30, 2007, 10:14:24 am by javeryh »
« Reply #25 on: March 30, 2007, 10:15:38 am »
I'd either do the whole door or leave it alone.  That just looks too hard to do perfectly and one of those things you'll always look at and be annoyed by if it's not.
« Reply #26 on: March 30, 2007, 10:22:28 am »
I think all those pieces come off so I could spray paint them individually.  Maybe this weekend I'll take everything apart and put some masking tape on everything and then spray them pink.  If I don't like the look I can always take off the tape - if I do then I can spray the parts for real.  It's a win-win, I think...
Aurich
« Reply #27 on: March 30, 2007, 12:47:13 pm »
Not going to look good. Even if you paint it perfectly it's going to look very out of place, like you ran out of parts. I understand you've got a pink theme, but there's too much of a good thing. Look at your control panel, it's black, the coin door will look fine matching that. Either go all pink to hide it or leave it black. If you want a pink accent on the door then you need an actual design. I gotta go pick up something soon, if it comes out nice check my project thread for an idea of how you can bring a design to the coin door. ;)
« Reply #28 on: March 30, 2007, 01:23:06 pm »
Agreed.  After staring at it for a while I don't like it at all.  I sure wish I could get those clear assemblies though...
« Reply #29 on: March 30, 2007, 01:31:35 pm »
Do you actually need the ability to insert coins?  If you do away with the coin slot and just go with a rectangular button it will be a lot easier to source.
« Reply #30 on: March 30, 2007, 02:06:43 pm »
I guess not...  I kind of want the coins to work though so I can limit my daughter's play time (hand her $5 in quarters/tokens and let her play until they are gone).  It will also force her to get good at the games she likes.  Are you talking about Randy's coin buttons?  Can those be swapped in for the assemblies?
« Reply #31 on: March 30, 2007, 02:10:20 pm »
I'm talking about any rectangular buttons.
Now that I think about it, if you don't need coins, what do you need buttons for?
Tiger-Heli
    • Tiger-Heli
« Reply #32 on: March 30, 2007, 02:25:11 pm »
I wonder if you could use the red buttons and some type of translucent white paint on the interior of the button and get more of a pink tint . . .
« Reply #33 on: March 30, 2007, 02:26:57 pm »
Wouldn't work, the red plastic is still on the outside of the paint.  You'd just end up with a dimmer red button.
« Reply #34 on: March 30, 2007, 02:34:11 pm »
OK, here's an idea...  what if I used colored LEDs behind the colored assembly to try and produce a pink color according to the color wheel?
What if I somehow got a purple LED behind the red plastic?  According to the wheel, Red and Purple make Pink.  Any reason why this wouldn't work?
« Reply #35 on: March 30, 2007, 02:36:29 pm »
Yes, because it's not equal parts.  You're shining purple light through a red lens.  It's not combining red and purple lights.  There's a small chance it would shine pink light on your leg but it's not going to magically change the red lens to pink.
Tiger-Heli
    • Tiger-Heli
« Reply #36 on: March 30, 2007, 02:38:09 pm »
I mentioned the UV LED's looked closest to what you were looking for from the pictures on the site I posted.
I also think either red through blue or blue through red could get you purple with would blend in better with the pink theme than red will.
« Reply #37 on: March 30, 2007, 02:42:40 pm »
If he doesn't need the button/coin slot function he could just cut a small piece of plexi to fit in the slot that is any color he wants.  Hell, he could even animate it.
« Reply #38 on: March 30, 2007, 02:47:42 pm »
Nope, it doesn't work that way.  If you put a blue LED behind a red filter, you get squat :)
Read what I wrote in the post above.
Tiger-Heli
    • Tiger-Heli
« Reply #39 on: March 30, 2007, 03:03:13 pm »
I did.  What about blue or red 194 wedge bulbs?  Same thing or not?
