Author Topic: Would this layout work good  (Read 1290 times)
Hawk Daddy
  • Last login:June 15, 2025, 03:10:44 pm
  • Only True Pimps Have Arcade Machines!!!
« on: March 26, 2007, 11:22:31 pm »
So I decided to hack xbox controllers, and I think thats the easiest way to do it.  Cause I want to make sure that all the controls work well.  And that way I'll be putting some effort into this project.  And I can solder pretty good.  I tested how I could do this with an arcade stick that I have for my xbox, and I soldered it up and it worked right, so I know that I can get it to work like I need it too.  So then I just decided to get another arcade stick, and use the boards on them.  Cause Thats easiest for me to do.  This is the layout that I cam up with, and I would like some input from some of the veterans in this hobby.
Any input is greatly appreciated.  I will have two of these on the CP, and I'll be using the same housing as I had with the MERCS cabinet.  So there will be plenty of room.  Thanks.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Steel Talons 2 player helicopter game
Hawk Daddy
Re: Would this layout work good
« Reply #1 on: March 27, 2007, 02:08:36 pm »
here is maybe a better layout with the start and select still on the left, just not pictured.
Still need your opinions.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
« Reply #2 on: March 27, 2007, 02:38:54 pm »
Some comments:
1.  The buttons are too far apart.
2.  The buttons look like they are on a 45 degree angle - I think it might be more comfortable if they were at a 20-30 degree angle - or maybe 2 rows lined up on top of each other like the blue, yellow and orange are positioned.
2.  I don't think that the Start and Select buttons are in a good location.  When you are resting your left hand on the panel I think you will be accidentally hitting them quite often.
« Reply #3 on: March 27, 2007, 02:43:44 pm »
Like this (but more even since I did this in 30 seconds in Paint):
Hawk Daddy
« Reply #4 on: March 27, 2007, 10:37:45 pm »
Ok so I redid it with what you have said and I've came up with this
I think that it will work well, as the start and select/back have been moved to infront of the joystick, and the others where reangled.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
