Author Topic: PS2 Repair Questions  (Read 2895 times)
Hoagie_one
  • Um....whats a cabinet
« on: March 26, 2007, 08:09:24 am »
I got a PS2 that is in great shape.  However, when ever you put a disk in, it makes a kind of grinding noise, almost like the drive is catching on something and is having a hard time spinning.  It reads disks, but takes a long time to load them.  To the point that its basically unplayable because of the slow read times.
Now, I've fixed disk read errors int eh past, but this seems different and I just wanted some opinions before I crack the case open and start on this one.
taternutz
  • Last login:June 15, 2011, 08:47:22 pm
  • lovin tots since 78
Re: PS2 Repair Questions
« Reply #1 on: March 26, 2007, 09:30:10 am »
check to see if the laser rails are dry. I had the same prob as the laser was moving very slowing and had that grinding noise also.
Hoagie_one
« Reply #2 on: March 26, 2007, 09:59:36 am »
what do you mean by dry rails?  Lube?  What can they be lubed with?
northerngames
  • Trade Count: (+18)
« Reply #3 on: March 26, 2007, 10:33:06 am »
the laser rails are the poles that the laser slide's back and forth on I like to use hair clipper oil on them as loob like said from the other member try that and if it is still doing it see if the pitch screw is to tight it is  a little black screw on the arm of the laser that slide's on the pole it also adjust the angle of the laser toward the disk so just check it and make sure it is not tight and cuasing it to skip or drag but not to loose either becuase of the angle it may cuase disk read errors and last if still doing check the laser height adjuster it may be to lowor to high and hitting something.
and only other thing I can think of is pull the top off and try it and see if the laser keeps hitting the spindle motor repeatidly and if so the black arm that sense's the motor needs to stop before it hits it is either worn out or broken off.
Hoagie_one
« Reply #4 on: March 26, 2007, 10:40:50 am »
thx.  I'll check it all out and get back to you if there is still problems.
taternutz
« Reply #5 on: March 26, 2007, 03:12:13 pm »
thnx northern for the followup on that :cheers:
Sprucemoose
  • Last login:March 23, 2009, 03:56:10 pm
  • You Spent How Much?!
« Reply #6 on: March 27, 2007, 03:22:28 am »
I believe the problem has to do with the height of the laser.  The grinding noise is a dead givaway.  If you take off the cover and eject the disc tray you will see a white circular cog.  You can turn this to raise or lower the height of the laser.  Its a tedious process, but easy to do.  Mark where you started, move it one direction, one click at a time.  Try disc.  If problems persist then repeat process.  If it gets worse go in opposite direction.  As long as you mark where you started you should be fine.
Good luck and PM me if you get stuck.
northerngames
« Reply #7 on: March 27, 2007, 03:59:57 pm »
it will reset itself to the lowest setting if you raise it to high if you over do it on one direction like stated above.
whatzcrackn
  • Last login:January 19, 2019, 12:14:02 pm
  • U just won tickets to da 'GUN SHOW'
« Reply #8 on: March 29, 2007, 05:00:25 pm »
Who does PS2 mods on here?  Any recomendation on the type of chip?
Hoagie_one
« Reply #9 on: March 30, 2007, 08:40:00 am »
The rails were fine.  It ended up being that the lazer was geared up too high.  I lowered it a couple of notches and its all good.  Just need to test it on a few more games to be sure, but god of war 2 ran great.
Naru
  • Last login:June 29, 2007, 12:01:34 am
« Reply #10 on: March 30, 2007, 08:47:55 am »
DMS4 Pro SE
