Author Topic: What size are holes for leaf buttons?  (Read 2384 times)
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
« on: March 25, 2007, 02:42:31 pm »
Just curious what the standard size holes were for leaf buttons. I know 1-1/8" is too small.
whammoed
  • Last login:Today at 05:25:57 pm
  • Crack don't smoke itself
    • NiceMite
Re: What size are holes for leaf buttons?
« Reply #1 on: March 25, 2007, 03:20:23 pm »
1 3/16 is large enough for leafs.
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
« Reply #2 on: March 25, 2007, 03:25:34 pm »
If you're using original butons, remember that most of them have little guide tabs so they won't rotate in the holes.  This won't be a prob if your hole is big enough, but they won't sit flush if the hole is exactly the size of the inserted base.  Sometimes you can slap them down flat with your hand, but you may need to file a tiny groove on each side of the hole to make it fit.
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
whammoed
    • NiceMite
« Reply #3 on: March 25, 2007, 09:28:14 pm »
Good point.  In wood, sometimes you can get them to "squish" down.  In metal, you either cut out the little triangles with a file, or cut off the tabs on the button with a utility knife.
spidermonkey
  • Last login:October 01, 2023, 04:15:59 am
  • Bombjack junkie
« Reply #4 on: March 25, 2007, 10:34:07 pm »
I was told that those little teeth were there to dig into the wood and  keep the button from spinning in wood control panels. I've also seen metal control panels that have the little notches to accomodate the little teeth on leaf switch buttons. My leaf switch buttons are in 1 1/8" holes but they were VERY tight going in. Take Whammoed's advise and drill 1 3/16" holes and they should fit without filing off the teeth/tabs. Never hurts to experiment using a piece of scrap wood first.
"Sinistar has bad breath"
spidermonkey
  • Bombjack junkie
« Reply #5 on: March 25, 2007, 10:41:57 pm »
Or you can follow Modessitt's advise which I failed to read before posting ::) :-[
Crowquill
« Reply #6 on: March 26, 2007, 12:56:55 am »
They'll be going into a metal CP, so maybe I can just file out the slots so I don't have to buy another hole saw or punch (1-1/8" is tough enough to find).
Unfortunately, I found this out the hard way when my leaf buttons didn't fit after drilling 15 holes in my MAME cab's CP.  :(
I bought a big lot of used buttons off of eBay a while back and figured I'd use them for my cocktail. Some of them look like new. Most don't. Most are the type used on Williams cabs (some of them are Joust blue and pale yellow). I believe these were Wico buttons.
Thanks for the suggestions.
whammoed
    • NiceMite
« Reply #7 on: March 26, 2007, 11:46:48 am »
If you need to widen existing holes in metal, you need one of these:
http://cgi.ebay.com/10-size-1-16-Unibit-M2-Ti-Step-Drill-Bit-13-16-to-1-3-8_W0QQitemZ120101536948QQcategoryZ50384QQrdZ1QQcmdZViewItem
$23 shipped, and a great tool to have around.
