Author Topic: Silly T-Molding Question  (Read 2103 times)
hedge
  • Last login:October 07, 2003, 10:49:00 pm
« on: April 10, 2003, 09:13:14 pm »
I finally picked up the 1/16" slot cutter bit and will be routing my side panels for the t-molding this weekend.  My question is:
Do I cut the slot ALL the way around the side panel, or just the areas that are clearly visible??  I suppose I also need to know this to know how much t-molding to buy as well...
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re:Silly T-Molding Question
« Reply #1 on: April 10, 2003, 10:02:57 pm »
I'd say the top and front, but that's me.  Of course, thats how I've seen every cab do it.
AX
  • Last login:April 20, 2004, 02:07:53 pm
  • The only way to win is to cheat!
« Reply #2 on: April 10, 2003, 10:08:00 pm »
I went all the way around.  actually my buddy did the routing on this cab so HE went all the way around.
Justin
  • Last login:November 25, 2025, 10:20:05 pm
    • Centipede MAME cabinet
« Reply #3 on: April 10, 2003, 11:26:15 pm »
My original Centipede cab is routed all around.
That's also the way I would do it
"3 warps to Uranus" -- so I stopped playing!
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #4 on: April 11, 2003, 02:01:04 am »
Is there fabric on the back of your sofa?  It is also possible that one day the back of your cab will be visible.  T-mold the back.  I would argue, though, that you can leave the bottom of your cab unroutered/t-molded  :)
Best Kid iPad Apps
VMJ Team
  • Last login:July 09, 2007, 09:29:50 am
    • Virtual Music Jukebox
« Reply #5 on: April 11, 2003, 03:45:54 pm »
I'd t-mold all the way around...even on the bottom.  It helps when sliding your cab around on carpeting, plus it provides a buffer for damage when moving the cabinet.
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #6 on: April 11, 2003, 03:56:49 pm »
Another reason to route all the way around is that even if you decided not to put molding on the bottom, you would have the slot in place if you change your mind later.
This opinion was created from 100% post consumed information.
hedge
« Reply #7 on: April 11, 2003, 07:21:59 pm »
Thanks for the advice.  I have decided to route all the way around.  That's the way I was leaning, but needed some reassurances...  :)
thedemo
  • Last login:May 21, 2003, 06:30:04 pm
  • I want to rule the world
« Reply #8 on: April 12, 2003, 10:44:07 am »
Word of advice
Cut the slots before you assemble the cab. Its alot easier to cut the slots when you can lay the pieces flat on sawhorses than when its assembled and standing upright.
hedge
« Reply #9 on: April 14, 2003, 10:32:58 pm »
I just asked this in another thread, but how deep should I route the slot around the sides?  The 1/16" bit I bought will cut 1/2" deep.  Will this be ok?
Thanks!!
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
« Reply #10 on: April 15, 2003, 01:39:42 am »
yep. rout it as deep as the slot cutter will go.
Infrasonic
  • Last login:May 20, 2003, 01:28:03 pm
« Reply #11 on: April 20, 2003, 03:45:37 am »
I build small arcade sticks and my 3/32 slot cutter stops at 1/2 inch deep sometimes going right through critical areas.  I set the fences on my router table so it doesn't go more than 3/8 deep now.
