Author Topic: Can you run Nebula M2 from the command line or a batch file?  (Read 1505 times)
Tiger-Heli
    • Tiger-Heli
« on: March 22, 2007, 12:26:27 pm »
I e-mailed ElSemi to ask also, but maybe someone on here knows a workaround:
Is there any way to launch the emulator in full screen and exit out of it from a command line or batch file.
I am thinking something like:
Emulator.exe zerogun -fs
And then just pressing Esc would exit, but I tried various combinations and couldn’t find a way to do this.
The launch currently works as follows:
Double-click emuloader.exe
Select File-Load ROM.
Double-click Rom name.
Select View - Switch to Full Screen.
Play game.
Exit.  (Sometimes works, sometimes doesn't)
I suppose I could maybe use some type of mouse-recording software, but I have not had good luck with those in the past . . .
Thanks!!!
Re: Can you run Nebula M2 from the command line or a batch file?
« Reply #1 on: March 22, 2007, 05:37:08 pm »
You might want to just hold off...
.113u3  of mame is supposed to fix most if not all m2 games.
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: March 26, 2007, 07:48:02 am »
Okay, thanks - I thought it would probably make it's way into MAME before too long one way or another anyway. . .
