Author Topic: Oil-Based Paint - How do you clean up??  (Read 2966 times)
« on: March 18, 2007, 01:33:16 pm »
I've thrown away a roller and a brush because I can't clean the oil-based paint off.  I know oil and water don't mix - what am I supposed to do?
Kaytrim
  • I'm too nice a guy
Re: Oil-Based Paint - How do you clean up??
« Reply #1 on: March 18, 2007, 02:14:20 pm »
Use gasoline or paint thinner in a jar to soak the brush and clean it up.  Throw the roller away.
fatfingers
  • Last login:April 17, 2025, 05:26:08 pm
  • Got UltraStiks?™
« Reply #2 on: March 18, 2007, 04:20:59 pm »
If you don't like those options, I suggest baby oil!
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
W.W.P.M.D.?                                       I'm here to help ... I just don't do it. ™
am_monkee
  • Last login:April 29, 2009, 09:48:45 am
« Reply #3 on: March 18, 2007, 08:11:40 pm »
or lighter fluid. when i was a smoker (ahhh...the good old days), I used to use lighter fluid from zippo for clean ups. it's also great at taking wood stain off your hands.
ScottS
  • Last login:November 01, 2007, 02:21:30 pm
« Reply #4 on: March 19, 2007, 06:43:04 pm »
Read your paint can: whatever is recommended as the thinner is probably good for clean-up, too. Brushes are usually pretty easy to clean-up using the appropriate solvent (paint thinner, mineral spirits or whatever). Rollers can be more difficult to clean. One alternative is to drop them into a Zip-lock freezer bag, squeeze all the air out, and throw them in the refrigerator. They'll last for months like that, maybe more...
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #5 on: March 19, 2007, 10:04:25 pm »
A good way to make clean up easier is to condition your brushes with whatever the paint can recommends as a thinner or for clean up. Just soak the brush in the solvent and remove the excess. The light coating of the solvent will make clean up a lot easier.
It's 9am. I'm calling it a nite.
DrFrag
  • Last login:December 15, 2011, 10:14:47 am
    • MAME Cab Worklog
« Reply #6 on: March 20, 2007, 12:00:57 pm »
I use mineral turpentine.  It doubles as a paint thinner, and triples as something to wash the paint off your hands.
Once most of the paint is out of the bristles, rinse in a bucket (one you don't mind getting paint on) using warm soapy water.  Squeeze them out and lay them on newspaper to dry.  Separate the bristles with a comb before it dries completely.  The whole process is a real pain.
Don't get turpentine on plants or grass if you shake your brushes out, it'll kill them.
I've heard paint rollers can't be cleaned.
