Author Topic: hiscore diff (with no nag/white box removal)  (Read 920072 times)
0 Members and 11 Guests are viewing this topic.
Donkbaca
    • Slim built MAME/Xbox cab
Re: hiscore diff (with no nag/white box removal)
« Reply #560 on: January 11, 2011, 11:51:26 am »
and set the compiler optimize for "none"
You have to start fresh from scratch.  No big deal, it takes like a minute to re-download everything.  I would delete headkazes' compiler and the mame programs you have, then follow the compiler instructions from the start.  Re-downlad the source code, re-download the diffs and set the compile optimize for none.
When I first tried to compile my own version, I had some fits too, but then headkaze replied to start from scratch and optimize for none and it worked like a charm.  It takes like an hour to compile
Paul Olson
    • Paul's Arcade
« Reply #561 on: January 11, 2011, 01:07:47 pm »
Does MAME compiler require .net? I know I installed a program recently that required .net 2, but I am not sure if this was it. I am at work, so I can't look it up right now.
abelenki
  • Last login:January 04, 2026, 10:56:26 pm
    • MAME Stuff
« Reply #562 on: January 11, 2011, 01:24:01 pm »
no, mingw doesn't requre Microsoft .NET.
MAME Stuff | MAME favorites | Bubble Bobble Series chart / wiki | PC configuration
wonderalex
  • Last login:January 19, 2025, 07:48:29 pm
« Reply #563 on: January 11, 2011, 03:24:00 pm »
Ok - starting from scratch got headkaze's compiler to work - BUT- after following the instructions I get this error when I click GO:
Compiling Mame...
mingw32-make: *** No targets specified and no makefile found.  Stop.
Finished!
0 Hours 0 Minutes and 0 Seconds Elapsed.
I'm using the 1.17 version of the compiler.
Any ideas?[/s]
EDIT: I must be blind -  I tried it again and I figured out what I did wrong.  I unzipped the source file into the correct directory - BUT I did not know/notice that the ZIP I downloaded from MAME dev contained another ZIP file!  :banghead: Once I unzipped that file and ran it again - everything worked as advertised.
WonderAlex
« Last Edit: January 11, 2011, 11:59:21 pm by wonderalex »
WhereEaglesDare
    • My HomePage
« Reply #564 on: January 15, 2011, 09:28:30 am »
Chris BEANS
  • Last login:April 01, 2013, 01:10:50 pm
« Reply #565 on: January 16, 2011, 03:17:30 pm »
Never compiled MAME before, followed the instructions in post 1 of this thread, and used Headkaze's compiler (again following the instructions on his download page).
Had it all done and dusted in around 45 minutes, now exactly as it says on the tin, I've got MameUI0.141 with no nag screens and high score support. Brilliant :D
Thanks loads to MKChamp and Headkaze, this will make my mame box so much cleaner. Chuffed :)
RVZ
  • Last login:November 07, 2025, 03:28:50 pm
    • Metal Slug!
« Reply #566 on: January 17, 2011, 04:37:28 am »
...I've got MameUI0.141 with no nag screens and high score support. Brilliant :D
Quick question... is it necessary to compile your own Mame if I just want to enable high scores?  It looks a bit complicated.  I don't really care about the nag screens, but I would like to save the high scores.  Can't I just create the "hi" folder and copy the .dat file?
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #567 on: January 17, 2011, 06:09:10 am »
There are several pre-built versions of mame floating around that have those already compiled in:
http://sourceforge.net/projects/groovyarcade/files/Mame_Windows_Builds/
MagicManPA
  • Last login:January 12, 2019, 04:35:43 pm
« Reply #568 on: January 17, 2011, 11:29:56 pm »
I created the "hi" folder, but I'm still not seeing MAME save my hi scores. I'm running v140.
abelenki
    • MAME Stuff
« Reply #569 on: January 18, 2011, 12:31:01 am »
official MAME doesn't support this, that's why this patch was introduced in the first place. you have to compile it yourself.
RVZ
    • Metal Slug!
« Reply #570 on: January 20, 2011, 01:36:32 am »
I tried 2 different pre-built versions last night.  I installed Mame, then just replaced the mame.exe file.  Is that correct?  In HyperSpin, when I want to start a game, the screen just flashes and goes back to the menu.  I can start mame separately as well, but when I select a game, it flashes and goes back to mame.  Am I doing something wrong?
WhereEaglesDare
    • My HomePage
« Reply #571 on: January 20, 2011, 07:31:18 am »
That sounds like it could be bad roms.
Try to run it without any frontend.  Do they work there?
RVZ
    • Metal Slug!
« Reply #572 on: January 20, 2011, 09:27:13 am »
Nope, but it works if I just use the original mame, without the pre-built exe file.  So the roms are fine.
Donkbaca
« Reply #573 on: January 20, 2011, 11:44:59 am »
You have to completely delete the old mame, the new one is getting confused, I would install it in a completely different place and point to all the folders in the old location.
MagicManPA
« Reply #574 on: January 20, 2011, 01:13:06 pm »
I tried to doing this w/HeadKaze's compiler following the steps listed on the download site, but it didn't work for me. I assume I did it wrong, but I have no idea.
I'm running v.140
Bonechip
  • Last login:June 10, 2012, 12:24:52 am
    • "The Arcade Machine"
« Reply #575 on: January 24, 2011, 06:16:18 pm »
MKChamp,
Your the best. Thanks again for keeping the High Score Diff up-to-date.
MKChamp
  • Last login:December 24, 2025, 01:30:45 pm
  • Stil around.
« Reply #576 on: January 24, 2011, 10:37:31 pm »
No problem. I'm far from the best, though!
EvilDindon
  • Last login:December 03, 2014, 11:34:33 am
« Reply #577 on: January 26, 2011, 06:12:04 am »
I'm running v.140
Man, Do you have the hiscore.dat file in your mame folder ?
milhouse
  • Last login:March 02, 2023, 08:03:32 pm
« Reply #578 on: February 02, 2011, 11:27:11 pm »
Anyone seen this issue?
I followed Mr. Do's instructions to the letter, and everything works up to and including patching the v141 source with hi_141.diff.  When I try to run MakeMame, though, the system can't find mingw32-make.
I've edited the bat file to update the path, but it doesn't look like mingw32-make is in the updated path (C:\MinGW\mingw64-w32\bin) or in anyMinGW subfolder for that matter.  I have now tried on two different machines.
Any thoughts?  Thanks.
WhereEaglesDare
    • My HomePage
« Reply #579 on: February 02, 2011, 11:47:14 pm »
Try HeadKaze's MAME Compiler, you'll thank me tomorrow.
milhouse
« Reply #580 on: February 03, 2011, 12:00:19 am »
Thanks.  It actually didn't work on one of the machines so i skipped it on the other, but now it seems to be working.
abelenki
    • MAME Stuff
« Reply #581 on: February 09, 2011, 11:58:12 am »
awesome. hi_141u1.diff seems to be compatible with MAME 0.141u2 source tree.
damn, i was still compiling u1...
p.s.: anyway, MKChamp, thanks for the great work!! ;)
« Last Edit: February 09, 2011, 12:03:02 pm by abelenki »
B2K24
  • Last login:June 10, 2025, 10:17:56 am
« Reply #582 on: February 09, 2011, 07:54:57 pm »
Yep we wait for hi_141u2.diff   ;)
MKChamp
  • Stil around.
« Reply #583 on: February 10, 2011, 01:33:51 am »
You guys are too quick for me :-)
I think it would have worked still. The only thing that failed was do to a space.
At any rate, 141u2 is ready. Download and go.
And thanks for hosting........
edit...I tried to be quck like yall...it doesn't work. I'll get it going and post back when it's all good. Whiskey..activated.
edit....Ok...all is good, Download and game it up.
« Last Edit: February 10, 2011, 03:41:53 am by MKChamp »
abelenki
    • MAME Stuff
« Reply #584 on: February 10, 2011, 04:55:13 am »
thanks a lot!! that was quick. ;)
B2K24
« Reply #585 on: February 10, 2011, 11:15:58 am »
Great work as always MKChamp, it's very much appreciated.
I don't even bother to run the newest build until your work is posted  ;)
abelenki
    • MAME Stuff
« Reply #586 on: February 10, 2011, 11:41:51 am »
hehe, same here. i compile fresh u-release only to scan for missing ROMs/CHDs. then wait for MKChamp's diff to compile 'full-featured' MAME. ;)
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« Reply #587 on: February 15, 2011, 12:58:42 am »
I'm trying to compile using headkazes compiler v1.2 and mame 141u2 with the highscore diffs.  I get this error at the end of the compile and have no mame.exe or anything?
Compiling src/osd/windows/video.c...
src/osd/windows/video.c:255: error: redefinition of 'void windows_osd_interface::update_hi(bool)'
src/osd/windows/video.c:233: error: 'virtual void windows_osd_interface::update_hi(bool)' previously defined here
make: *** [obj/windows/mame/osd/windows/video.o] Error 1
Finished!
0 Hours 42 Minutes and 34 Seconds Elapsed.
Any ideas what I'm doing wrong?
Update:  Okay, I managed to get 141 with no updates compiled correctly, obviously it is something to do with they way I'm applying all the updates..??
« Last Edit: February 15, 2011, 06:55:30 pm by stuzza »
Pitou
  • Last login:July 01, 2025, 12:33:17 pm
« Reply #588 on: February 17, 2011, 11:25:05 pm »
Hi MKChamp,
It seems that since 0.141 refreshrate doesn't work anymore.
I remember reporting this 2 or 3 years ago and you did fix it correctly.
Is it possible that the same problem is occuring again?
Thank you.
Pitou!
EDIT: After some extensive tests, I think I found the problem. Mame 139 works fine, but not since mame 140... It seems that the refreshrate parameter is not taken into account anymore.
« Last Edit: February 18, 2011, 12:44:41 am by Pitou »
kaptainsteve
  • Last login:November 22, 2025, 09:12:21 pm
    • Swamp-Ass
« Reply #589 on: March 01, 2011, 08:05:33 pm »
Hello,
I ran into a couple problems compiling mame with Mr. Do's page.
1. He never says anything about a patch.exe file.  Unless I am mistaken, you need to put a patch.exe in the mamesrc folder and you must get that here;
http://sourceforge.net/projects/gnuwin32/files/patch/2.5.9-7/patch-2.5.9-7-bin.zip/download
2. Where do you start w/the Diff patches?  For example, I am compiling 141_u3 and I've downloaded mame src 141.  do i start w/patch 140, then u1, u2 and finally u3 or do i start with 141_u1?
3. What do you do when you apply .diff patches and you get a previously detected patch message???  Do you click y or n?
4.  It says on Mr. Do's page  to type in "Makemame"  but that does not work.  You must type in "Make" only.
Thanks, and any suggestions are welcome, please.
Think I figured it out.  With the update .diffs, you only use the hiscore update for the last one, and you use the regular mame updates for the previous.
« Last Edit: March 10, 2011, 04:11:22 pm by kaptainsteve »
WhereEaglesDare
    • My HomePage
« Reply #590 on: March 01, 2011, 10:28:03 pm »
Use HeadKaze's MAME Compiler.
Pitou
« Reply #591 on: March 14, 2011, 09:52:52 pm »
Hello,
Just compiled mame 141u3 with the high score diff, but the result exe crash. It seems to be worse with galaxian. It works about 1 out of 2.
Any idea?
Pitou!
« Last Edit: March 15, 2011, 10:43:40 am by Pitou »
headkaze
  • 0x2b|~0x2b?
« Reply #592 on: March 15, 2011, 05:53:55 pm »
Any idea?
Try turning off any optimization.
Pitou
« Reply #593 on: March 15, 2011, 07:05:14 pm »
I have not turned on any optimization. I never had any problem before. Very strange...
I just uncompress the source, then apply the patch and do a make -j3
Anyway, I'll try again.
Pitou!
Pitou
« Reply #594 on: March 15, 2011, 09:32:54 pm »
I just found out that by setting this:
disable_nagscreen_patch   1
Of course I get the "white box", but I can now start Galaxian 100% of the time. No more crash.
Pitou!
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« Reply #595 on: March 24, 2011, 01:07:22 am »
Trying to compile 0141 and having a problem. I was wondering if anyone has a suggestion? I am not a complete noob and have compiled sucsessfully in the past. I have tried both the old skool Mr Do's method and HeadKaze's MAME Compiler and have the exact same error message with both methods.. I have no problem applying the hi_141.diff (it patches just fine).  The error is upon compiling and happens within 10 secs or so. Here is what I am getting. ANy help would be greatly appreciated.  The c:\docum~1\KEITH is my documents folder. What is even causing it to look there for anything?  :dizzy:
 'C:\DOCUME~1\KEITH' is not recognized as an internal or external command,
operable program or batch file.
The system cannot find the path specified.
make: *** [obj/windows/mame/emu/cpu/m68000/m68kmake.o] Error 1
C:\mamesrc>
My old user name was marlborroman13, but I kicked the habit many years ago!
B2K24
« Reply #596 on: March 26, 2011, 12:34:49 am »
try any other drive and don't compile on C:\
If you have to buy a USB flash or use external. For me trying to compile on win 7 using C:\ is always problems because some directories have lock icons even with UAC disabled and logged on Admin account.
Thanks MKChamp for new diff same day as mamedev release source update. Thank you very much for your work :)
AMDman13
« Reply #597 on: March 29, 2011, 12:31:49 am »
Thanks, I finally gave up and ran a compile using my laptop which has Vista as the OS and  everything worked fine. Working sweet! Thank you for the .diff!
B2K24
« Reply #598 on: April 04, 2011, 12:39:38 am »
THANK YOU for 0.142  \o/
abelenki
    • MAME Stuff
« Reply #599 on: April 04, 2011, 02:21:02 am »
ditto. thanks a lot for the prompt update!!
